No worries
. I do not think that the ram configuration is stored in the BIOS at all as it is needed to be known before the GPU even reads the BIOS from the EEPROM. In earlier versions it was based on the hard straps, I do not see any reason why they would have changed this.
Well that's good news then
![Cheesy :D](https://www.eevblog.com/forum/Smileys/default/cheesy.gif)
, I was scared of flashing the 4GB BIOS in case it messed up because of the missing 1GB, and the 2GB one had me scared because of some different values in spots that matched between the 3GB 660 and 4GB 670, if that's true then the 4GB one is sounding even better
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
As for the RAM size, from what I can see, that module is 2Gb which is 0.25GB per chip * 6 = 1.5GB total. This is very odd unless I am also reading it wrong if you say that the card should have 3GB of RAM. Can you have a real close look at the card to be doubly sure that the part number you provided is correct? Also, you did count the chips on both sides of the PCB?
I took some pictures of the chips while I had it open:
Haven't checked the other side yet because of some metal grille covering it, I can see some sort of thermal paste coming through the holes of it though. I'll take it out later and have a check for definite.
As for seeing cards with less ram accessible then is physically installed, I highly doubt this would ever occur, the cost saving to the mfg is too large to just disable/hide/waste the additional RAM.
Ah yeah that's true, probably should have thought of that before I took it apart
![Grin ;D](https://www.eevblog.com/forum/Smileys/default/grin.gif)
Think I might wait and buy another 3GB 660 Ti when I get money, don't really want to go without if it messed up
![Undecided :-\](https://www.eevblog.com/forum/Smileys/default/undecided.gif)
If you get hold of a 670 can you note down the resistors? Might come in handy if the BIOS does some sort of check.
Edit: nevermind, just saw that it would be 5K and 10K, bit slow today
![Face Palm :palm:](https://www.eevblog.com/forum/Smileys/default/facepalm.gif)
I'll pull the card out and take a peek under the grille now
Edit2: Yep, the other 6 were there, along with another 2 unfilled spaces
![Sad :(](https://www.eevblog.com/forum/Smileys/default/sad.gif)
Oh well, heres some pictures:
http://imgur.com/a/TolyJ#8Now check out
http://images.anandtech.com/doci/5818/GeForce_GTX_670_B-1.jpgLook similar?
This is a normal 2GB 660 Ti (best pic I could find):
http://rwlabs.com/images/articles/evga/660ti_superclock/08.JPGSeems like this board might have a good chance
Edit3: Looking around led me to this spot for the resistors:
Which seems to have a different config to the 670:
http://www.ixbt.com/video3/images/ref/gtx670-scan-back.jpgI admit I'm no good when it comes to hardware though, so I'm probably wrong about this... Don't really have any idea how I'd find out where they are, this was just me checking for similarity
![Embarrassed :-[](https://www.eevblog.com/forum/Smileys/default/embarrassed.gif)
Edit4: Remembered you saying about when it's pulled in a different direction it's a different set of values...
90% sure this is the spot now, hope you can tell us more
