Hi everybody!
Thanks for great work and a lot of usefull information!
Successfully hacked two cards only with Nvflash:
Palit GTS 450 to Quadro 2000 - Works with passthrough in Esxi 5.5 and in Xenserver 6.2 and in Xen 4.4
Inno3D GT 9800 to Quadro FX2800M - Works with passthrough in Xenserver and Xen, and does NOT work in Esxi (fails with BSOD)
Third card - Palit GTX 660 2 gb, tried to mod it to a K4000 ID of 11FA.
Resistors was replaced in accordance with
THIS post.
On this Palit pcb in area of flash chip the same as on EVGA GTX 660.
I had no 15K resistor so I put 16K. And it's looks ok. The 4th nibble is A.
But..
1. 3rd nibble is buggy: Mostly it's F, but sometimes (eg. after xen host reboot) it became "E". And even if I put 40K resistor in R3H on topside.
2. Passthrough does not work. Tested in Xen when ID was ok - 11FA. In device manager there is yellow triangle - error code 43.
Any suggestions?
