Author Topic: Rubbish directories?  (Read 1428 times)
Offline PerranOakTopic starter
« on: June 06, 2020, 11:32:49 am »
I have Windows 8.1 and on the C: drive a load of weird directories (screen capture attached).
Mostly, they contain just one file: MRT.exe
Some have a few files such as:
Windows6.0-KB938979-x86.cab
Windows6.0-KB938979-x86.xml
Windows6.0-KB938979-x86-pkgProperties.txt
WSUSSCAN.cab
Are these rubbish, i.e. can I delete them?
Cheers.
You can release yourself but the only way to go is down!
RJD
Offline greenpossum
Re: Rubbish directories?
« Reply #1 on: June 06, 2020, 11:39:04 am »
They look like updates that were automatically downloaded and probably applied. Better to get a cleanup program that can decide what to delete. I used to use bleachbit.
Offline Syntax Error
« Reply #2 on: June 08, 2020, 09:19:31 pm »
They're the junk a Windows install accumulates over it's lifetime. Often these are update files and restore points. Be carefull deleting them manually as Windows Update may get out of step and kill your machine's response by trying to do a retrospective update. The only issue is these files get fragmented all over the disk map and refuse to 'defrag' because they're protected system files.
Try running the Windows Disc Cleanup Tool (built-in) which should offer a 'Windows update cleanup' option.
The following users thanked this post: PerranOak
