Author Topic: FOX DELTA ANTENNA ANALYSER WONT WORK WITH MY LENOVO TAB.  (Read 1330 times)
Offline m3vuvTopic starter
« on: October 14, 2019, 10:50:47 am »
Hi all,i have a fox delta antenna analyser with the bluetooth modual installed,it works fine on my galaxy s2,but my lenovo TB-X103F wont sort of find it,it sees the bt modual and pairs ok but when i run the analyser program it says swr-a board not found,i emailed the company about this,this was the reply:
paul .a larner
8:44 AM (2 hours ago)
Hi,ive built the bt adaptor,it works fine with my samsung galaxy s2 but when i try to use it with my lenovo tab,no good,the tab finds it and pairs ok but the annalyser program cant find the swra board.
Fox Delta Kits
10:04 AM (1 hour ago)
to me
Hello
Reason is: each android OS in each model of mobile has special set of permissions. These specific permissions block display of content on screen.
You have to study your OS and those special permissions/block scripts that mobile manufacturer has installed.
73s/DGajjar
any ideas what i need to do to fix this?
Offline PA0PBZ
Re: FOX DELTA ANTENNA ANALYSER WONT WORK WITH MY LENOVO TAB.
« Reply #1 on: October 14, 2019, 10:54:57 am »
Assuming that your tablet runs Android 6 have a look here: https://www.tomsguide.com/us/android-marshmallow-app-permissions,review-3287.html
The following users thanked this post: m3vuv
« Reply #2 on: October 14, 2019, 12:34:55 pm »
Im afrait that didnt help,thanks tho.
Offline PA0PBZ
« Reply #3 on: October 14, 2019, 01:28:38 pm »
The amount of information is underwhelming, so I assume you don't want any further help?
« Reply #4 on: October 14, 2019, 02:19:38 pm »
well what information do you want?
Online Bud
« Reply #5 on: October 14, 2019, 02:25:14 pm »
The information i want is why you posted the topic title in ALL CAPS
Offline PA0PBZ
« Reply #6 on: October 14, 2019, 02:56:35 pm »
For example what did you try after reading the link I posted, why didn't it help?
Could you find where to change the settings? Could you change the permissions?
And yes, please don't touch the Caps-Lock key ;)
« Reply #7 on: October 15, 2019, 07:42:54 am »
Sory about the caps,i followed the steps in the link you sent,the analyser app had full permissions so wasnt anything to change,my phone runs android ver 4.42,that works fine with it,my tab runs android ver 6.0.1
kernel version 3.10.49 hope this helps.
Offline PA0PBZ
« Reply #8 on: October 15, 2019, 08:06:33 am »
Thanks for the better explanation. Since I don't have the analyzer or the app please tell the guys from fox delta that you checked and that the app has full permissions and see what they can suggest.
« Reply #9 on: October 16, 2019, 04:30:07 am »
i mailed fox delta,a couple of replies but nothing usefull!.
