Author Topic: Cliff CP30105 USB 3.0 connector cable?  (Read 974 times)
Offline ckambiselisTopic starter
« on: April 02, 2020, 04:54:38 pm »
Got these connectors for a project but I'm starting to regret it, tried 3 times to make a PCB connector adapter from the 1.27mm pitch double row header they have used to the standard USB 3.0 internal header found on motherboards that converts to USB 3.0 A male but still can't get it right, the idea is to use them as an extensions to bring the female USB A ports from a micro pc housed inside a waterproof enclosure to the side of that enclosure. Is there anyone who has used these and has found a ready made cable. This is what I'm working with, also before you start telling me that there is that classic style panel mount extension, I will also add that, since this is a standard XLR shell, there are water/dust guards for it, for when there isn't anything connected.
« Last Edit: April 04, 2020, 02:59:20 pm by ckambiselis »
Offline rdl
Re: Cliff CP30105 USB 3.0 connector cable?
« Reply #1 on: April 04, 2020, 08:04:35 pm »
Seems like it'd be simpler to use the regular ports instead of motherboard connector. Something like this would probably do the job.
https://www.tme.eu/en/details/1310-1019-01/usb-ieee1394-connectors/encitech/
The following users thanked this post: ckambiselis
« Reply #2 on: April 10, 2020, 05:49:51 pm »
Nice, hadn't seen that one and it's also from the distributor I always use, one thing though is that the cable is a bit on the long side, the enclosure I'm using is actually just a few centimeters bigger than the Thinkcenter, main reason is that the system needs to be mobile.
But https://www.tme.eu/en/katalog/data-connectors_31/?visible_params=613%2C1382%2C2%2C1182%2C536%2C82%2C416%2C419%2C1322%2C516&mapped_params=536%3A1436558%2C1438554%2C1436558%2C1460610%2C1438864%2C1460610%3B613%3A1447311%3B1382%3A1493258%3B it seems that there are actually shorter ones and from Amphenol, well I see where was the problem, they are under the Connectors category and not the Cables.
Thank you very much.
