Thanks for the detailed reply.
Yes, thanks , we do full system backups with Marcium before any such work !
A liitle more of the PC history, originally an older Intel i3 with its HD4400 inbult graphics which started to give strange problems, ended up fitting a cheap Nvida card to get going.
Updated the mobo, cpu, ram with an i3 12100 and its UHD 730 graphics and once validated upgraded to W11, and then Defender started showing the problem with the Memory Integrity section.
The existing Intel programs, as below were removed one at a time, rebooted, but those files still remained when we again checked in the Memory Integrity window.
Reloaded the drivers using Intels program but again no change to those files .
Restored C: to its original state and Uninstalled the driver via Device Manager as you suggested and used the Intel program to reinstall the latest drivers, but sadly no change.
So still a bit stuck with those files, though like you said , we have run for some time without it, just that it would seem good to use it noow we have the extra measures the new hardware and W11 offer.
The last resort will be a clean full resintall, just that would be nice if we could avoid that for a while longer.
![Old PC Drivers Removal ?](https://www.eevblog.com/forum/index.php?action=dlattach;topic=368810.0;attach=1738883;image)
![Old PC Drivers Removal ?](https://www.eevblog.com/forum/index.php?action=dlattach;topic=368810.0;attach=1738889;image)
