What do you see, a ton of processes using a ton of CPU all without your permission and not doing stuff in your best interests?
i got a much much bad impression than that...
Try for example to see how the "
ownership" of things are handled...
Just following how things are
mounted doing a simple mount (which is included by default in the weird path) ... and if you can use adb a lsblk and lsblk -a ...
The weirdest thing you can see happens when you have
applets moved to sdcard..
It is a total messy crazy shit... I am sure some folk behind this can explain the rationale for that...
but the sake of buying a crippled device... best CPU/GPU with a *NIX kernel like.. that..
just a **** piece of ****
![Roll Eyes ::)](https://www.eevblog.com/forum/Smileys/default/rolleyes.gif)
Paul
