Yes I really wanted to see a Server in a 48U rack, one of the very top start leaking water to the others down him... Yes, a full rack burned...
So I will break my answer in serveral parts:
Physical properties of water versus air and mineral oil
Risks of water use and historical bad experiences
Total cost of cooling a datacenter
Weakenesses of classic liquid cooling systems
Physical properties of water compared to others
First a few simple rules:
Liquid can transport more heat than gases
Evaporating a liquid extract more heat (used in refrigerator)
Water has the best cooling properties of all liquids.
A moving fluid extract heat way better than a non moving fluid
Turbulent flow requires more energy to be moved but extract heat way better than laminar flow.
If you compare water and mineral oil versus air (for the same volume)
mineral oil is around 1500 times better than air
water is around 3500 times better than air
oil is a bad electricity conductor in all conditions and is used to cool high power transformers.
oil depending on its exact type is a solvant and is able to dissolve plastic
water is a good conductor of electricity if it is not pure (contains minerals...) otherwise not
water is a good electrolyt. So metals put in contact with water can be dissolved under certain conditions.
Now some comments about what I said above: Comparisons are made at atmospheric pressure. In this condition water boils at 100°C which is above the maximum temperature for processors. So when cooling with water, water stays liquid. Cooling with organic compounds like mineral oil or freon(what is used in refrigerator) is a classical method of cooling for some application (power plants, military vehicules...) but long term use of oil in direct contact with plastic has never been done in the IT sector. So its influence on the reliability of server parts is unknown (Green Evolution doesn't say a word about is). Making you liquid move is important. Relying on natural movement inside a non moving liquid to remove heat is inefficient and directing correctly a liquid without pipe is difficult. For these reasons, immersion cooling is far from being the perfect solution to cooling issues.
Technical issues
Making air move is easy and leaks are not a threat to safety (to efficiency well). It requires a lot of space and consume energy (15% of your desktop cinsumption goes to your fans)
Making a liquid move is troublesome. You need pipes, cooling blocks (cold plates) attached to every component you want to cool, a tank, a pump and maybe a filter. Moreover, servicing such a system is difficult since you need to remove the liquid. But it requires less space and requires less energy.
Another important point is that a lot of reasearch and standardization has been down on how to design motherboards,desktop and servers based on a air based system with cooling fans. And the resulting designs are not adequate for liquid based systems. More info at formfactors.org
Risks
Water cooling systems can leak if your design is poorly done. Heat pipes are a good example of a liquid based system that has no leak (look on here for more info)
Common water cooling systems cool only hot component and thus still require an air flow for other component. So you have 2 cooling systems instead of one and you degrade the performances of your air cooling system.
With standard designs, a water leak has an huge risk of causing a lot of damage if it enters in contact with metal parts.
Remarks
Pure water is a bad conductor of electricity
Nearly every part of electronic components are coated with a non conductive coating. Only solder pads are not. So a few drops of water can be harmless
Water risks can be mitigated by existing technical solutions
Cooling air reduces its capacity to contain water (humidity) and so there is a risk of condensation (bad for electronics). So when you cool air, you need to remove water. This requires energy. Normal humidity level for a human is around 70% of humidity.So it is possible that you need after cooling to put back water in your air for the people.
Total cost of a datacenter
When you consider cooling in a datacenter you have to take into account every part of it:
Conditioning the air (filtering, removing excess humidity, moving it around...)
Cool and hot air should never mix otherwise you lower your efficiency and there is a risk of hot spot (points that are not cooled enough)
You need a system to extract the heat in excess or you have to limit the heat production density (less servers per rack)
You may already have pipes to remove the heat from the room (to transport it up to the roof)
The cost of a datacenter is driven by its density (amount of servers per square meter) and its power consumption. (some other factors enters also into account but not for this discussion) Total datacenter surface is divided into the surface used by the server themselves, by the cooling system, by the utilities (electricity...) and by servicing rooms. If you have more server per rack, you need more cooling and so more space for cooling. This limits the actual density of your datacenter.
Habits
A datacenter is something highly complex that requires a lot of reliability. Statistics of downtime causes in a datacenter say that 80% of downtime are caused by human errors.
To achieve the best level of reliability, you need a lot of procedures and safety measures. So historically in datacenters, all of the procedures are made for air cooling systems and water is restricted to its safest use if not banned from datacenters. Basically, it is impossible for water to ever come into contact with servers.
Yes there are companies like HP who have water cooling solutions, and I saw them too, but very rare and in specific cases.
Technically water is better
Server design and datacenter designs are not adapted to water cooling
Current maintenance and safety procedures forbid the use of water cooling inside servers
No commercial product is good enough to be used in datacenters
Commercial product, not proprietary product made by a manufacture that only fits the same manufacture in specific cases.
Yes. All over the place. The advent of AIOs has transformed the marketplace. I'm seeing them in high-end workstations, ready-made gaming rigs and even training simulators. Anywhere you have high-demand workload and want to keep it cool quietly.
I'm the guy they call to air-drop in and clean up the mess when nobody else is willing to. My days are spent going from one business or datacenter to another, replacing network gear, CPUs, RAM, VRMs and PSUs in places locked down so tightly you need an escort and you put your phone in a locker before you enter.
Even in THOSE places I've been seeing liquid-cooled servers for years now. They use AIOs specifically configured for those servers; but the general config is the same: pump is still on the CPU, the chassis is designed so you can lift the entire cooler out as an assembly without disturbing the rest of the MB and the cooler is treated as a consumable supply. You are literally thinking 10 years ago technology, not today's. ![Face Palm :palm:](https://www.eevblog.com/forum/Smileys/default/facepalm.gif)
Cheers,
![Tweak :-/O](https://www.eevblog.com/forum/Smileys/default/smiliey_cal.gif)
You don't know what I do, you don't know where I worked to assume that you are the only one with access to places so secure you need an escort... But well... I really will stop, nothing can really go through thick heads.
I hope the OP get the best config he can with the help of the ones who really know what they are saying... Or say in the correct way without conflict.
