Author Topic: UNI-T UT61E freaks out ...  (Read 4872 times)
Offline LEECH666Topic starter
« on: April 14, 2012, 10:26:15 pm »
Not quite sure if I am doing smth. wrong here ...
What do you think?
Cheers,
Florian
Offline Monkeh
Re: UNI-T UT61E freaks out ...
« Reply #1 on: April 14, 2012, 10:57:07 pm »
Well the issue with the probes is that they're dirty. Residue from the moulding. Clean them with a PVC solvent.
As for the autoranging, mine doesn't do that but it might be an odd artifact of that transformer. Send me a transformer to try! :P
Offline T4P
  • Country: sg
    • T4P
« Reply #2 on: April 15, 2012, 12:31:13 am »
Oh , nevermind , even the metrix freaks out now .
« Last Edit: April 15, 2012, 04:45:25 pm by Dave.S »
Offline onlooker
« Reply #3 on: April 15, 2012, 01:21:07 am »
One possible explanation is that when your ut61e is doing resistance check, the auto range switching interfares with the inductive load. Likely (theoretically), this can happen only for load with particular values. A good test is to repeat what you did in the video, but with a scope attached to see the range switching. In the worst case (theoretically) the voltage may go reversed.
« Last Edit: April 15, 2012, 01:22:53 am by onlooker »
« Reply #4 on: April 15, 2012, 02:08:20 pm »
I just did what onlooker suggested. There are some intersting pulses there ...
UT61E in auto range mode
Pulse detail 1
Pulse detail 2
UT61E in manual range mode
Apparently my Metrix freaks out too.
Cheers,
Florian
« Last Edit: April 15, 2012, 02:13:28 pm by LEECH666 »
