Author Topic: Hantek - Tekway - DSO hack - get 200MHz bw for free  (Read 2248830 times)
Offline tinheadTopic starter
Re: Hantek - Tekway - DSO hack - get 200MHz bw for free
« Reply #1350 on: September 05, 2012, 07:06:54 am »
By ugrading sw, the problem is solved
so you upgraded to latest fw from the website (2.06.3_120808.0) and the 0x2 error is solved?
Good to know. Still, let's hope Hantek tell us the original reason.
Offline Jane
« Reply #1351 on: September 05, 2012, 09:55:43 am »
@tinhead: I was  sent dst1kb_2.06.3_15062b_fact(120808.2).up file. If anyone needs it  I can upload somewhere. After updating, self calibration is OK.
Offline Jane
Re: Measure menu
« Reply #1352 on: September 05, 2012, 09:58:42 am »
Can anyone explain why I receive different values when measuring frequency?
Please see the picture.
Why is the difference of the frequency on the bottom line( which is correct) and the frequency on the measuring menu( which is incorrect) ?
Thanks
« Last Edit: September 05, 2012, 10:04:22 am by Jane »
Offline aghp
« Reply #1353 on: September 05, 2012, 11:39:54 am »
You are looking some kind of low freq alias.
Change Horizontal setting to around 20ns/div or somethink like this.
Still trigger counter (bottom of display) may give different (more accurate) freq than mesuring from displayed cycle.
Trigger counter is real counter.
EU: Owon oscilloscopes and in Finland also  some Siglent selected equipments. All with our  lab deep Q.C. in Finland.  Surplus test equipments. Repair service. 40 year experience about electric and electronic repair, service and design. Local Owon SDS-Series  repair service for our customers.
Re: Measure menu
« Reply #1354 on: September 05, 2012, 11:58:58 am »
Jane,
these DSOs have hardware frequency counter integrated - the bottom status line is showing the frequency from that counter.
The measure menu is however calculating the frequency from the waveform data, so far everything ok.
In some special case you might see difference between both values.
In your special case the measure menu frequency is such low because of undersampling - tis is here a clear aliasing effect.
Check
http://en.wikipedia.org/wiki/Undersampling
http://en.wikipedia.org/wiki/Aliasing
Without hardware frequency counter you would be lost, here you can easy recognize that something wrong
with sampling rate because of the (almost) always perfect hardware frequncy counter results.
Offline Jane
« Reply #1355 on: September 05, 2012, 12:42:45 pm »
Thank you for help.
When I changed Horizontal setting it works very good. But I have another problem/question.
I compared that hacked DSO5262 with the unhacked DSO5262.
And trigger counter( on bottom status)  shows about 199 Mhz measuring frequency with both DSO5262.
Is that normal?
How can I test then the hacking was successful?
Thanks
« Reply #1356 on: September 05, 2012, 01:45:51 pm »
Is that normal?
Jane,
the hack have no influence on counter, it works anyway up to 400+MHz.
if you can set horizontal to 2ns/DIV then the hack was successful.
Offline Jane
« Reply #1357 on: September 05, 2012, 03:27:03 pm »
@tinhead:Thanks for the reply.
Please check th e  blue arrow in  the enclosed picture if I understand well.
Thanks
Offline mightyzen
« Reply #1358 on: September 12, 2012, 08:10:52 pm »
Could you upload the .2 firmware? The hantek site still provides the .0 firmware. Thanks.
Offline Jane
« Reply #1359 on: September 13, 2012, 08:02:46 am »
The file is too big.It does not allowed to upload here.send me a location where I should upload
« Reply #1360 on: September 13, 2012, 08:34:17 am »
use winrar or winzip and split files or upload to a file hoster like e.g. hotfile.com
Offline Jane
« Last Edit: September 13, 2012, 04:18:35 pm by tinhead »
Offline mightyzen
« Reply #1363 on: September 13, 2012, 04:11:11 pm »
Thanks!
« Reply #1364 on: September 15, 2012, 06:27:41 pm »
i've posted here small review of Tekway newest MSO
https://www.eevblog.com/forum/product-reviews-photos-and-discussion/mixed-signal-oscilloscope-from-tekway/
this is in principle nothing else than DSO like from this thread (must be hw1007 version) with extra addon PCB
and special firmware to allow MSO/LA!
The very cool thing is, everybody having Tekway DSO1062B, 1102B, 1202B, or Hantek DSO5062B, DSO5102B, DSO5202B
or Voltcraft DSO-3062C can pimp such DSO to MSO ... all you need it such extra PCB and firmware, and the good part
is, i spoke with Tekway and they will provide me all we need!
Offline rapsac
« Reply #1365 on: September 15, 2012, 10:58:35 pm »
I just noticed that conrad.nl has the VOLTCRAFT DSO-3062C (art. no. 122464) back in stock for 299€. I just ordered one and registered on this forum as it is THE place for the hanteks ;)
conrad.de has it in stock also.
edit: sold out already.
« Last Edit: September 16, 2012, 10:18:42 pm by rapsac »
Offline Crenwick
« Reply #1366 on: September 16, 2012, 08:48:55 am »
@ Tinhead
I'm also interested in the MSO/LA but I checked my DSO and it's a HW1007 board but the PCB header socket (2mm) to connect the LA board is not installed.
Can I solder one myself ? Did I have to add something else to my DSO ?
Thanks,
Bernard
« Reply #1367 on: September 16, 2012, 10:32:59 am »
I will deliver all the necessary small parts. This means also that you will get :
- 1.27mm pin header
- 2 screews
- distance holder
- 5cm flat cable with 20pin IDC plug (to connect DB25 socket to LA/MSO PCB)
- DB25 socket
- DB25 header
You will not get any test cables, but they are really cheap on ebay 251150864536
All you will have to do is to:
- backup firmware (over USB flash drive with backup tool)
- remove sticker (front panel near USB) to expose the hole for DB25 socket. Every hw1007 have such hole.
- solder cable to DB25 socket (the IDT20 cable which will be pluged into LA PCB)
- mount this DB25 socket to front panel. I think there are already holes in the shielding, when you remove the sticker
  you will see immediately if there is any drill work necessary.
- solder the 1.27mm pitch header to DSO PCB
- mount the LA PCB to DSO PCB
- connect the IDT20 cable (from DB25) to LA
- reconnect all other DSO cables, so you can boot DSO.
Boot DSO and install new firmware. You will need for this UART<->PC connection and deatiled description how to
do this. I will get special crafted firmware (actually complette dump), this must be complettly restored to DSO
overwriting the old version. The biggest advantage : you will have newer Linux version, which is anyway necessary to
get network working. In Germany i'm offering "instalaltion service", so everybody who don't wish to play with
UART/USB to install firmware or solder cables/header can get this step done by me (for a small fee).
So as long you have :
- screwdriver
- solder station
- UART<->USB adapter cable
- max 2GB USB flash drive
it's not so much to do.
Offline MEGABLINK
« Reply #1368 on: September 16, 2012, 10:53:35 am »
Hello tinhad,
Firstly, i wanna thank you for all the research in these scopes (firmware cracks/fixes, hardware schematics, troubleshooting, etc).
I study the hw schematics, because i am working on a DSO project on my own, and i use the schematics from HanTekway as documentation reference.
May i ask if you can upload the Altium Designer project (schematics)?
Best regards,
MEGABLINK
Offline Crenwick
« Reply #1369 on: September 16, 2012, 11:15:23 am »
Thanks for the information,
I will send you a PM  ;)
Bernard
- 1.27mm pin header
- 2 screews
- distance holder
- DB25 socket
- DB25 header
- screwdriver
- solder station
Offline amigo
  • Professional Wannabe
« Reply #1370 on: September 16, 2012, 12:58:02 pm »
Crap, my hw version is below hw1007 as I have a less dense expansion connection. :(
Is there a way to get this working on the older hw versions, and if not, why not?
Thanks.
Offline yoq
« Reply #1371 on: September 16, 2012, 08:44:05 pm »
Hello eevblog forum,
I finally bought a hantek dso5102b myself, primarily because of the great research done by tinhead and others. Big thanks to all contributers!
A few people mentioned WiFi dongles, and I really liked that idea, so I got a 10€ one from amazon. It has a realtek chipset, and they provide linux sources for the driver. They claim it only works from kernel 2.6.18+ but it compiles just fine for the hantek kernel. It took a while, but i managed to compile all the little programs for a wifi connection. Now my scope logs into my wifi automatically and gets its IP via DHCP.
The attached zip contains these files:
iwconfig, iwlist, iwXXXXWireless tools (http://www.hpl.hp.com/personal/Jean_Tourrilhes/Linux/Tools.html)
wpa_supplicantHandles wireless network encryption WPA/WPA2
ifplugdChecks for the adapter and runs a script when plugged in/out
8192cu.koDriver for realtek 8192 / 8188 chipset + different versions (syslog off, powersaving off)
+scripts and the network config file (/etc/wpa.conf)
+modified /etc/init.d/rcS, to load driver, telnet, inetd, and ifplugd
If you have a different dongle than the EDIMAX EW-7811UN you might need to compile your own kernel module, but as long as it has a realtek chipset, there should be no problems.
@tinhead
Is there any chance of getting network support for the DSO-app on the bench models?
I tried to activate it by writing the [net]1 to the EEPROM, but I couldn't connect with ttscope or dreisiebners' dso-tool.
Taking a screenshot wirelessly seems like a very neat feature to me, so already tried to grab it directly from the framebuffer, but /dev/fb0 seems to be unused.
« Last Edit: September 16, 2012, 08:46:56 pm by yoq »
Offline condor
« Reply #1372 on: September 16, 2012, 10:52:34 pm »
How will the MSO/LA modification affect the future  firmware upgrade path for the DSO5000?
Offline Crenwick
« Reply #1373 on: September 17, 2012, 05:34:37 am »
I suppose you will have to follow the MSO path  8)
Offline Jane
Problem with changing logo
« Reply #1374 on: September 18, 2012, 12:14:50 pm »
Did anyone try to hack DSO5102BM?
I bought DSO5102BM few days ago only and wanted to hack it.
 But I noticed it uses a different software.
E.g. I need not use
 killall dsod command
to enter console and also  booting is different.
I were not able to change logo and not sure if the hack was really successful.
It shows DSO5202B( as I wanted) but not sure if it also works as DSO5202B.
Besides when it starts booting it shows
*** Warning - bad CRC or NAND, using default environment
##### EmbedSky BIOS for SKY2440/TQ2440 #####
Press Space key to Download Mode !
Booting Linux ...
Copy linux kernel from 0x00200000 to 0x30008000, size = 0x00200000 ... Copy Kernel to SDRAM done,NOW, Booting Linux......
Uncompressing Linux... done, booting the kernel.
Linux version 2.6.30.4 (root@rain-fc4) (gcc version 4.3.3 (Sourcery G++ Lite 2009q1-176) ) #9 Mon Dec 12 11:50:21 CST 2011
CPU: ARM920T [41129200] revision 0 (ARMv4T), cr=c0007177
CPU: VIVT data cache, VIVT instruction cache
Machine: TQ2440
Thanks for help.
