DECA MAX10 Board Configuration
Pin Assignments:
Pin Assignment Table:
CLOCK
Name Location Direction Standard
ADC_CLK_10 M9 input 2.5 V
MAX10_CLK1_50 M8 input 2.5 V
MAX10_CLK2_50 P11 input 3.3-V LVTTL
KEY
KEY[0] H21 input 1.5 V Schmitt Trigger
KEY[1] H22 input 1.5 V Schmitt Trigger
LED
LED[0] C7 output 1.2 V
LED[1] C8 output 1.2 V
LED[2] A6 output 1.2 V
LED[3] B7 output 1.2 V
LED[4] C4 output 1.2 V
LED[5] A5 output 1.2 V
LED[6] B4 output 1.2 V
LED[7] C5 output 1.2 V
CapSense Button
CAP_SENSE_I2C_SCL AB2 inout 3.3-V LVTTL
CAP_SENSE_I2C_SDA AB3 inout 3.3-V LVTTL
Audio
AUDIO_BCLK R14 inout 1.5 V
AUDIO_DIN_MFP1 P15 output 1.5 V
AUDIO_DOUT_MFP2 P18 input 1.5 V
AUDIO_GPIO_MFP5 M22 inout 1.5 V
AUDIO_MCLK P14 output 1.5 V
AUDIO_MISO_MFP4 N21 input 1.5 V
AUDIO_RESET_n M21 inout 1.5 V
AUDIO_SCLK_MFP3 P19 output 1.5 V
AUDIO_SCL_SS_n P20 output 1.5 V
AUDIO_SDA_MOSI P21 output 1.5 V
AUDIO_SPI_SELECT N22 output 1.5 V
AUDIO_WCLK R15 inout 1.5 V
Flash
FLASH_DATA[0] P12 inout 3.3-V LVTTL
FLASH_DATA[1] V4 inout 3.3-V LVTTL
FLASH_DATA[2] V5 inout 3.3-V LVTTL
FLASH_DATA[3] P10 inout 3.3-V LVTTL
FLASH_DCLK R12 output 3.3-V LVTTL
FLASH_NCSO R10 output 3.3-V LVTTL
FLASH_RESET_n W10 output 3.3-V LVTTL
G-Sensor
GSENSOR_PD AB5 output 3.3-V LVTTL
GSENSOR_ST AA5 output 3.3-V LVTTL
HDMI-TX
HDMI_I2C_SCL C10 inout 1.8 V
HDMI_I2C_SDA B15 inout 1.8 V
HDMI_I2S[0] A9 inout 1.8 V
HDMI_I2S[1] A11 inout 1.8 V
HDMI_I2S[2] A8 inout 1.8 V
HDMI_I2S[3] B8 inout 1.8 V
HDMI_LRCLK A10 inout 1.8 V
HDMI_MCLK A7 inout 1.8 V
HDMI_SCLK D12 inout 1.8 V
HDMI_TX_CLK D6 output 1.2 V
HDMI_TX_D[0] C18 output 1.8 V
HDMI_TX_D[1] D17 output 1.8 V
HDMI_TX_D[2] C17 output 1.8 V
HDMI_TX_D[3] C19 output 1.8 V
HDMI_TX_D[4] D14 output 1.8 V
HDMI_TX_D[5] B19 output 1.8 V
HDMI_TX_D[6] D13 output 1.8 V
HDMI_TX_D[7] A19 output 1.8 V
HDMI_TX_D[8] C14 output 1.8 V
HDMI_TX_D[9] A17 output 1.8 V
HDMI_TX_D[10] B16 output 1.8 V
HDMI_TX_D[11] C15 output 1.8 V
HDMI_TX_D[12] A14 output 1.8 V
HDMI_TX_D[13] A15 output 1.8 V
HDMI_TX_D[14] A12 output 1.8 V
HDMI_TX_D[15] A16 output 1.8 V
HDMI_TX_D[16] A13 output 1.8 V
HDMI_TX_D[17] C16 output 1.8 V
HDMI_TX_D[18] C12 output 1.8 V
HDMI_TX_D[19] B17 output 1.8 V
HDMI_TX_D[20] B12 output 1.8 V
HDMI_TX_D[21] B14 output 1.8 V
HDMI_TX_D[22] A18 output 1.8 V
HDMI_TX_D[23] C13 output 1.8 V
HDMI_TX_DE C9 output 1.8 V
HDMI_TX_HS B11 output 1.8 V
HDMI_TX_INT B10 input 1.8 V
HDMI_TX_VS C11 output 1.8 V
Light Sensor
LIGHT_I2C_SCL Y8 output 3.3-V LVTTL
LIGHT_I2C_SDA AA8 inout 3.3-V LVTTL
LIGHT_INT AA9 inout 3.3-V LVTTL
Ethernet
NET_COL R4 input 2.5 V
NET_CRS P5 input 2.5 V
NET_MDC R5 output 2.5 V
NET_MDIO N8 inout 2.5 V
NET_PCF_EN V9 output 3.3-V LVTTL
NET_RESET_n R3 output 2.5 V
NET_RXD[0] P8 input 2.5 V
NET_RXD[1] R7 input 2.5 V
NET_RXD[2] U4 input 2.5 V
NET_RXD[3] U5 input 2.5 V
NET_RX_CLK T6 output 2.5 V
NET_RX_DV P4 input 2.5 V
NET_RX_ER V1 input 2.5 V
NET_TXD[0] U2 output 2.5 V
NET_TXD[1] W1 output 2.5 V
NET_TXD[2] N9 output 2.5 V
NET_TXD[3] W2 output 2.5 V
NET_TX_CLK T5 input 2.5 V
NET_TX_EN P3 output 2.5 V
Power Monitor
PMONITOR_ALERT Y4 input 3.3-V LVTTL
PMONITOR_I2C_SCL Y3 output 3.3-V LVTTL
PMONITOR_I2C_SDA Y1 inout 3.3-V LVTTL
Humidity and Temperature Sensor
RH_TEMP_DRDY_n AB9 input 3.3-V LVTTL
RH_TEMP_I2C_SCL Y10 output 3.3-V LVTTL
RH_TEMP_I2C_SDA AA10 inout 3.3-V LVTTL
MicroSD Card
SD_CLK T20 output 1.5 V
SD_CMD T21 inout 1.5 V
SD_CMD_DIR U22 output 1.5 V
SD_D0_DIR T22 output 1.5 V
SD_D123_DIR U21 inout 1.5 V
SD_DAT[0] R18 inout 1.5 V
SD_DAT[1] T18 inout 1.5 V
SD_DAT[2] T19 inout 1.5 V
SD_DAT[3] R20 inout 1.5 V
SD_FB_CLK R22 input 1.5 V
SD_SEL P13 output 3.3-V LVTTL
SW
SW[0] J21 input 1.5 V Schmitt Trigger
SW[1] J22 input 1.5 V Schmitt Trigger
Board Temperature Sensor
TEMP_CS_n AB4 output 3.3-V LVTTL
TEMP_SC AA1 output 3.3-V LVTTL
TEMP_SIO Y2 inout 3.3-V LVTTL
USB
USB_CLKIN H11 input 1.2 V
USB_CS J11 output 1.8 V
USB_DATA[0] E12 inout 1.8 V
USB_DATA[1] E13 inout 1.8 V
USB_DATA[2] H13 inout 1.8 V
USB_DATA[3] E14 inout 1.8 V
USB_DATA[4] H14 inout 1.8 V
USB_DATA[5] D15 inout 1.8 V
USB_DATA[6] E15 inout 1.8 V
USB_DATA[7] F15 inout 1.8 V
USB_DIR J13 input 1.8 V
USB_FAULT_n D8 input 1.2 V
USB_NXT H12 input 1.8 V
USB_RESET_n E16 output 1.8 V
USB_STP J12 output 1.8 V
