Hi, if I want to use a Lipo battery to power a PC motherboard which takes 12 to 19 Volt DC with a maximum current of 10A. Should I be using a 3S or 4S Lipo? What capacity and discharge rate should I be looking at if I want to run the PC for about 25 minutes? Given mAh*C of two batteries are similar, should I be choosing one with higher mAh or C value?
