Author Topic: External reset pin on MC9S08PA16 wont reset initially.  (Read 1454 times)
Offline CirclotronTopic starter
« on: October 08, 2020, 12:58:23 am »
A board I make has a MC9S08PA16. The datasheet says paragraph 2.2.4 say "A low on the RESET pin forces the MCU to an known startup state." The thing is, the RESET pin has multiple functions - PORTA5, IRQ, TCLK0 and RESET and I'm not sure RESET is the default. If I power it up then do a reset from the programmer it tells me the MCU is not responding so I cycle the power, press ok and it is reset. From that point onward the programmer can reset it. What am I doing wrong. I'm using a P&E USB multilink thing. Not sure what version the programming software is, I'll have to wait till I get home. It does seem pretty buggy.
Offline m k
Re: External reset pin on MC9S08PA16 wont reset initially.
« Reply #1 on: October 20, 2020, 09:44:49 am »
Maybe your other reset is too fast and it's not a real reset but something like low power.
Or maybe your USB port is hibernating and waking up takes time.
Or maybe the controller needs a falling edge.
Advance-Aneng-Appa-AVO-Beckman-Danbridge-Data Tech-Fluke-General Radio-H. W. Sullivan-Heathkit-HP-Kaise-Kyoritsu-Leeds & Northrup-Mastech-REO-Simpson-Sinclair-Tektronix-Tokyo Rikosha-Topward-Triplett-Tritron-YFE
