Author Topic: Working model of 74HC244 for LTSpice?  (Read 6684 times)
Online SiliconWizardTopic starter
« on: September 03, 2022, 07:35:52 pm »
Does anyone have a working model of a 74HC244, reasonably accurate, for LTSpice?
I've found various Spice models for it that definitely don't work in LTSpice. I can't afford spending hours trying to figure this out at the moment. So has anyone done it yet? :)
Re: Working model of 74HC244 for LTSpice?
« Reply #2 on: September 03, 2022, 08:57:24 pm »
Thanks. Yeah. I had found other similar libs, problem is they are not properly made to simulate the 74HC gates including power supplies. They are set up for fixed 5V Vcc.
What I'm interested in is simulating the "analog" behavior of those gates at various Vcc levels and most of all the transients when Vcc changes. Those cannot simulate that as far as I can see.
Offline tggzzz
« Reply #3 on: September 03, 2022, 09:16:50 pm »
For such analogue behaviour, you might start with IBIS models.
You could presume the semiconductors were infinitely fast, and that ground bounce and similar was due to the LCR devices specified in The IBIS model.
IIRC MicroCap can digest IBIS models, but not LTSpice.
« Reply #4 on: September 04, 2022, 12:54:14 am »
I'm less used to MicroCap than LTSpice, which is why I tend to default to the latter, but I did fire up MicroCap and spent a little time figuring this out and I could get what I want.
So, MicroCap it was. Great it has become free, but really a shame it's abandonware.
Offline tggzzz
« Reply #5 on: September 04, 2022, 09:24:27 am »
Agreed on all counts.
Glad it worked for you.
Offline iMo
  • Country: bt
« Reply #6 on: September 04, 2022, 09:40:25 am »
Is this a reasonably accurate model?
« Last Edit: September 04, 2022, 10:02:30 am by imo »
Offline tggzzz
« Reply #7 on: September 04, 2022, 09:50:23 am »
What does the model contain for the internal lead inductance?
Useful to switch all outputs simultaneously in the same direction when they are driving a representative load, and observe ground bounce.
Offline iMo
  • Country: bt
« Reply #8 on: September 04, 2022, 09:56:27 am »
First SW should define the "reasonably accurate model".
The simple logic one, with some prop delays, variable Vcc and some output load characteristics, or with added RLC parasitics, or with all cmos transistor models with their channel widths and lengths and material sheet resistances, or..?
For example (pspice models work in ltspice):
* SN74HC244.cir
* 2.0
* 2019-11-14 00:00:00
* Texas Instruments Incorporated.
* Standard Logic, SLHR
* 12500 TI Blvd
* Dallas, TX -75243
* Revision History:
* Rev 2.0: 01/01/2019
* - Model generated from datasheet values
* - Built using generic logic gate behavioral pspice model V2
* - Built using an automated model which generalizes parts under same family
* - Performance is expected typical behavior at 25C
* - Written for and tested with Tina-TI Version 9.3.100.244 SF-TI
* - Accurate power consumption with dyanmic as well as static Icc
*[Disclaimer]
* This model is designed as an aid for customers of Texas Instruments.
* TI and its licensors and suppliers make no warranties, either expressed
* or implied, with respect to this  model, including the warranties of
* merchantability or fitness for a particular purpose. The model is
* provided solely on an "as is" basis. The entire risk as to its quality
* and performance is with the customer.
*[Copyright]
*(C) Copyright 2019 Texas Instruments Incorporated.All rights reserved.
*                                 SN74HC244
.SUBCKT SN74HC244 Y A OEZ VCC AGND
XU1 Y A VCC OEZ VCC AGND LOGIC_GATE_2PIN_TRI_STATE_HC_1i_AND_Tristate_CMOS_SN74HC244
.ENDS
.SUBCKT LOGIC_GATE_2PIN_TRI_STATE_HC_1i_AND_Tristate_CMOS_SN74HC244 OUT A B OEZ VCC GND
.PARAM VCC_ABS_MAX = 7
.PARAM VCC_MAX = 6
.PARAM RA = 240000000
.PARAM RB = 240000000
.PARAM CA = 1e-11
.PARAM CB = 1e-11
.PARAM ROEZ = 5000
.PARAM COEZ = 3e-12
RA  A  GND {RA}
RB  B  GND {RB}
CA  A  GND {CA}
CB  B  GND {CB}
ROEZ OEZ GND {ROEZ}
COEZ OEZ GND {COEZ}
XUA NA A VCC GND LOGIC_INPUT_HC_1i_AND_Tristate_CMOS_SN74HC244
XUB NB B VCC GND LOGIC_INPUT_HC_1i_AND_Tristate_CMOS_SN74HC244
XUOEZ NOEZ OEZ VCC GND LOGIC_INPUT_HC_1i_AND_Tristate_CMOS_SN74HC244
XUG NA NB NOUTG VCC GND LOGIC_FUNCTION_2_HC_1i_AND_Tristate_CMOS_SN74HC244
XOUTPD NOUTG NOUTTPD VCC GND TPD_HC_1i_AND_Tristate_CMOS_SN74HC244
XUOUT NOUTTPD NOUT_INT NOEZ VCC GND LOGIC_TRI_STATE_OUTPUT_HC_1i_AND_Tristate_CMOS_SN74HC244
XICC VCC GND NVIOUT LOGIC_ICC_HC_1i_AND_Tristate_CMOS_SN74HC244
SICC VCC GND VCC GND SW1
H1 NVIOUT GND VIOUT 1
VIOUT NOUT_INT OUTsw 0
SIOFF OUTsw OUT VCC GND SW2
DA2 GND A D1
DB2 GND B D1
DO2 GND OUT D1
DOE1 NOEZ VCC D1
DOE2 GND OEZ D1
RDA1 NA1 GND 1e6
SDA1 NA1 A VCC GND SW2
RDB1 NB1 GND 1e6
SDB1 NB1 B VCC GND SW2
RDO1 NO1 GND 1e6
SDO1 NO1 OUT VCC GND SW2
.MODEL SW1 VSWITCH VON = {VCC_ABS_MAX} VOFF = {VCC_MAX} RON = 10 ROFF = 60e6
.MODEL SW2 VSWITCH VON = {0.55} VOFF = {0.45} RON = 10m ROFF = 100e6
.MODEL D1 D
.ENDS
.SUBCKT LOGIC_INPUT_HC_1i_AND_Tristate_CMOS_SN74HC244 OUT IN VCC VEE
.PARAM STANDARD_INPUT_SELECT = 1
.PARAM SCHMITT_TRIGGER_INPUT_SELECT = 0
ESTD_THR VSTD_THR VEE TABLE {V(VCC,VEE)} =
+(1,0.5)
+(1.8,0.9)
+(2.5,1.25)
+(3.3,1.65)
+(5,2.5)
+(6,3)
ETRP_P VTRP_P VEE TABLE {V(VCC,VEE)} =
+(2,1.2)
+(4.5,2.5)
+(6,3.3)
ETRP_N VTRP_N VEE TABLE {V(VCC,VEE)} =
+(2,0.6)
+(4.5,1.6)
+(6,2)
EHYST VHYST VEE TABLE {V(VCC,VEE)} =
+(2,0.6)
+(4.5,0.9)
+(6,1.3)
ETRUE NTRUE VEE VALUE = {V(VCC,VEE)}
EFALSE NFALSE VEE VALUE = {0}
EBETA BETA VEE VALUE = {V(VHYST,VEE)/(V(NTRUE,VEE) - V(NFALSE,VEE) + V(VHYST,VEE))}
EFB NFB VEE VALUE = {(1 - V(BETA,VEE))*V(IN,VEE) + V(BETA,VEE)*V(CURR_OUT,VEE)}
EREF NREF VEE VALUE = {0.5*(1 - V(BETA,VEE))*(V(VTRP_P,VEE) + V(VTRP_N,VEE))
+ + 0.5*V(BETA,VEE)*(V(NTRUE,VEE) + V(NFALSE,VEE))}
EDIFF NDIFF VEE VALUE = {V(NFB,NREF)}
ESWITCH VSWITCH VEE VALUE = {0.5*(-SGN(V(NDIFF,VEE)) + ABS(SGN(V(NDIFF,VEE))))}
ESWITCH1 VSWITCH1 VEE VALUE = {0.5*(SGN(V(NDIFF,VEE)) + ABS(SGN(V(NDIFF,VEE))))}
GCOMP VEE CURR_OUT VALUE = {SCHMITT_TRIGGER_INPUT_SELECT*0.5*V(VCC,VEE)*(SGN(V(NDIFF,VEE)) + ABS(SGN(V(NDIFF,VEE))))}
GSTD VEE CURR_OUT VALUE = {STANDARD_INPUT_SELECT*0.5*V(VCC,VEE)*(SGN(V(IN,VSTD_THR)) + ABS(SGN(V(IN,VSTD_THR))))}
ROUT CURR_OUT VEE 1
EMID MID VEE VALUE = {0.5*(V(VCC,VEE) + V(VEE))}
EARG NARG VEE VALUE = {V(CURR_OUT,VEE) - V(MID,VEE)}
EOUT OUT VEE VALUE = {0.5*(SGN(V(NARG,VEE)) + ABS(SGN(V(NARG,VEE) ) ) )}
.PARAM MAXICC = 0.0009
.PARAM VT = .7
.PARAM VCC_MIN = 2
EV_VT1 VTN VEE VALUE = { VT }
EV_VT2 VTP VEE VALUE = { V(VCC,VEE) - VT }
ETEST TEST VEE VALUE = {.9*V(VCC,VEE)}
EVTHDIFF VTH_DIFF VEE VALUE = {V(IN,VSTD_THR)}
EVTHPDIFF VTHP_DIFF VEE VALUE = {V(IN,VTRP_P)}
EVTHNDIFF VTHN_DIFF VEE VALUE = {V(IN,VTRP_N)}
EVTNDIFF VTN_DIFF VEE VALUE = { V(IN,VTN) }
EVTPDIFF VTP_DIFF VEE VALUE = { V(IN,VTP) }
GICCVA VCC VEE VALUE = { (-ABS(( (1+SGN(V(VTN_DIFF,VEE)) ) )/2 -1) *
+ 2*MAXICC*((V(IN,VEE)-VT)/V(VCC,VEE))^2)*(1 + SGN(V(VCC,VEE) - VCC_MIN))*V(VSWITCH,VEE)}
GICCVB VCC VEE VALUE = { (ABS(( (1+SGN(V(VTHP_DIFF,VEE)) ) )/2 -1) *
GICCVC VCC VEE VALUE = { ( ABS(  (1+SGN(V(VTHN_DIFF,VEE)) ) )/2  *
+ 2*MAXICC*((V(IN,VEE)-(V(VCC,VEE)-VT))/V(VCC,VEE))^2)*(1 + SGN(V(VCC,VEE) - VCC_MIN))*V(VSWITCH1,VEE)}
GICCVD VCC VEE VALUE = { (-ABS(  (1+SGN(V(VTP_DIFF,VEE)) ) )/2  *
.ENDS
.SUBCKT LOGIC_FUNCTION_2_HC_1i_AND_Tristate_CMOS_SN74HC244 A B OUT VCC VEE
.PARAM AND  = 1
.PARAM NAND = 0
.PARAM OR   = 0
.PARAM NOR  = 0
.PARAM XOR  = 0
.PARAM XNOR = 0
GAND  VEE N1 VALUE = {AND*V(A,VEE)*V(B,VEE)}
GNAND VEE N1 VALUE = {NAND*(1 - V(A,VEE)*V(B,VEE))}
GOR   VEE N1 VALUE = {OR*(MIN(V(A,VEE) + V(B,VEE),1))}
GNOR  VEE N1 VALUE = {NOR*(1 - MIN(V(A,VEE) + V(B,VEE),1))}
GXOR  VEE N1 VALUE = {XOR*((1 - V(A,VEE))*V(B,VEE) + V(A,VEE)*(1 - V(B,VEE)))}
GXNOR VEE N1 VALUE = {XNOR*(1 - ((1 - V(A,VEE))*V(B,VEE) + V(A,VEE)*(1 - V(B,VEE))))}
RN1 N1 VEE 1
EOUT OUT VEE N1 VEE 1
.ENDS
.SUBCKT TPD_HC_1i_AND_Tristate_CMOS_SN74HC244 IN OUT VCC VEE
.PARAM TPDELAY1 = 1N
.PARAM RS = 10K
.PARAM CS = {-TPDELAY1/(RS*LOG(0.5))}
ETPDNORM NTPDNORM VEE TABLE {V(VCC,VEE)} =
+(2,90)
+(4.5,18.5)
+(6,16)
G1 IN N1 VALUE = {V(IN,N1)/(V(NTPDNORM,VEE)*RS)}
RZ IN N1 10G
C1 N1 VEE {CS}
E1 N2 VEE VALUE = {0.5*(1 + SGN(V(N1,VEE) - 0.5))}
EOUT OUT VEE N2 VEE 1
.ENDS
.SUBCKT LOGIC_TRI_STATE_OUTPUT_HC_1i_AND_Tristate_CMOS_SN74HC244 IN OUT OEZ VCC VEE
EROH NROH VEE TABLE {V(VCC,VEE)} =
+(2,5000)
+(4.5,50)
+(6,38.4615384615385)
EROL NROL VEE TABLE {V(VCC,VEE)} =
+(2,100)
+(4.5,42.5)
+(6,28.8461538461538)
EOEZ N2 VEE VALUE = {1 - V(OEZ,VEE)}
E1 N1 VEE VALUE = {V(VCC,VEE)*V(IN,VEE)*V(N2,VEE)}
GOUT N1 OUT VALUE = {V(N1,OUT)*V(N2,VEE)*(V(IN,VEE)/V(NROH,VEE) + (1 - V(IN,VEE))/V(NROL,VEE))}
LOUT N1 OUT .1n
ROUT OUT VEE 1E8
.ENDS
.SUBCKT LOGIC_ICC_HC_1i_AND_Tristate_CMOS_SN74HC244 VCC VEE VIOUT
.PARAM ICC = 2.5e-07
.PARAM VCC_MAX = 6
.PARAM VCC_MIN = 2
GICC VCC VEE VALUE = {ICC*0.5*(1 + SGN(V(VCC,VEE) - VCC_MIN))}
EGNDF GNDF 0 VALUE = {0.5*(V(VCC) + V(VEE))}
GOUTP VCC GNDF VALUE = {V(VIOUT,VEE)*0.5*(SGN(V(VIOUT,VEE)) + ABS(SGN(V(VIOUT,VEE))))}
GOUTN GNDF VEE VALUE = {V(VIOUT,VEE)*0.5*(SGN(V(VIOUT,VEE)) + ABS(SGN(V(VIOUT,VEE))))}
.ENDS
« Last Edit: September 04, 2022, 11:07:30 am by imo »
Offline tggzzz
« Reply #9 on: September 04, 2022, 10:56:28 am »
Of course it should be software that models the hardware.
Preferably the aspects that are likely to cause problems in the circuit. Ground bounce was a major issue with the DIP variants of digital ICs, causing subtle unrepeatable with PCBs at customer premises. Not good!
* SN74HC244.cir
* 2.0
* 12500 TI Blvd
* Dallas, TX -75243
LOUT N1 OUT .1n
That's the only inductor I can spot, and I guess it is the inductance in a (too?) short signal output lead.
I don't see any inductance for the ground/Vcc leads; I would expect to see around 0.8nH/mm.
Offline iMo
  • Country: bt
« Reply #10 on: September 04, 2022, 11:01:57 am »
See the above simulation with that TI model, you may see the L in action  :D
No problem to add any other L to any wire inside the model, imho..
Feel free to play with parasitics  >:D
Offline tggzzz
« Reply #11 on: September 04, 2022, 11:23:21 am »
The simulation (you added to your post with the mainly incomprehnsible code) is entertaining.
The problem isn't adding parasitic components, it is knowing which parasitics are important and their values. That's why the IBIS models were invented and are important.
I'll note that for a small old FPGA (Spartan 6), the spartan6.ibs file is 34MB of text.
Offline iMo
  • Country: bt
« Reply #12 on: September 04, 2022, 11:33:15 am »
Yep, simulation with ltspice should be fun  :D
The incomprehensible code there is the TI model file, for even more entertainment - below you may see the entire picture..
« Last Edit: September 04, 2022, 11:35:05 am by imo »
Offline Leeonshow
  • Country: tw
« Reply #13 on: April 17, 2024, 10:38:50 am »
hello, i have a question about the parameters setting ,i am not really sure what the meaning about speed and  tripdt ,i think maybe it is related to rise/fall or delay, can anyone give me the suggestion ?
*the following picture is 74hc224's symbol which is download by this website
*the another picture is the datasheet spec about the ic
can anyone teach me how to use the datasheet's information to set the variation in 74hc224's parameters about speed and tripdt?
Offline temperance
« Reply #14 on: April 30, 2024, 11:22:59 pm »
This might help:
LT spice models for: Digital Libraries and components for LTspice: 74HCXX, CD4000, Switch 4053, 8-bit Encoder 4532, DVIEW
https://sites.google.com/view/j-marcos-alonso/home
See bottom of page for LT spice files and how to use them.
And a link to his YT channel:
https://www.youtube.com/@MarcosAlonsoElectronics
