Hello at all,
i am designing a bluetooth audio device with the TI's CC2560 and want to connect the bluetooth-antenna via an sma-connector. I already had kind of HF-stuff at my university but didn't use it until now in practical applications.
I have calculatet a W/d of 1.787 (where W is the trace width and d is the thickness of the board) for FR4 and it seems to be comprehensible from the plots but the trace is then much bigger than the trace in the routing guidelines of the chip (i expect because i only have 2 layers and they use 4 layers).
The antenna is only ~ 6mm away from the chip pin including a bandpass filter. I have to route the trace between two other chip pins so i am wondering if it makes sense to do as an example first a 6 mil trace to get from the chip to the bandpass filter and then continue with a 54.7 mil trace (calculated width using a 0.8mm thick board). For me it seems very strange...
I have added an image of the actual board to show what i mean
![Grin ;D](https://www.eevblog.com/forum/Smileys/default/grin.gif)
Could you please bring me some enlightenment?
![Roll Eyes ::)](https://www.eevblog.com/forum/Smileys/default/rolleyes.gif)
Thanks in advance
Elektrofreak
