Hello,
I'll start an HDI design which is going to be 10-layers with via in pad process (it's got a couple of fine pitch BGAs 0.4mm).
Since I am new to HDI tech. I am researching about it before I start. I learned about micro-vias (stacking them, staggering them etc), buried vias etc.
There are a few question that I'd like to ask. I understand that stacking micro vias requires extra steps in manufacturing, hence more expensive PCB. Is the same thing with stacking buried vias and micro vias? Does it also cost more than staggering them?
Here is a picture to demonstrate What I am trying to tell:
On the right a micro-via and a buried via are stacked. Does this require extra step or it's a standard process?
Thanks in advance!
