Author Topic: solder mask free area in Altium?  (Read 1552 times)
Offline xzswq21Topic starter
« on: December 17, 2017, 12:59:54 pm »
Hello
I want to define a solder mask free area on a PCB.
how should I define?
I couldn't find anything
Offline Deni
  • Country: hr
Re: solder mask free area in Altium?
« Reply #1 on: December 17, 2017, 01:06:28 pm »
Just draw on the solder mask layer whatever you want. Altium will correctly generate negative gerber images
The following users thanked this post: xzswq21
Offline ncoonrod14
  • EE Student
« Reply #2 on: December 26, 2017, 02:03:59 am »
First select the top solder layer and then use any of the shape options in the place menu. Alternatively, if you need something that isn't a line, rectangle, or arc. You can make the outline of what you want filled using the above tools, select those objects, and got to Tools/Convert/Create Polygon from selected primitives.
