Hello everyone. I have a machine shop at home and do the odd weird project. Currently I am trying to build a couple of PCB's for a custom volume potentiometer for a 1950-1960's preamplifier. I am using F360 Electronics and have the bulk of the boards built, but I cannot for the life of me work out how to do the ground and wiper traces for the board... and I am struggling to find a decent resource to help guide me through too. I have put a thread on Autodesk's forum but not had any responses yet.
I was hoping I could just create 2 rings of trace and then trim or block the parts I didn't want copper on, then drop a pad in these sections to link it with the schematic, but I just can't figure it out. The only way I have been able to get anything close so far, is making a rectangle pad and doing a circular array and use a large through hole for the center.
Is what I want to do possible in F360 and if so where can I get some support to try and solve this issue, or do I need to cut my losses and try a different program. I really like F360 for CAD work, but the electronics section is really hard to get to grips with.
For example, the outer array of long pads in this design should really be wedges with a small gap in between:
