Author Topic: LTspice Triac .model doesnt work  (Read 727 times)
Offline FaringdonTopic starter
« on: May 18, 2023, 06:11:39 pm »
Do you know why this triac model doesnt work in LTspice.
I got it here.
https://www.powerelectronicsnews.com/power-supply-design-note-simulating-a-triac/
'Perfection' is the enemy of 'perfectly satisfactory'
Offline Weston
Re: LTspice Triac .model doesnt work
« Reply #1 on: May 18, 2023, 06:35:02 pm »
Sometimes models you find online do not match the expected pin ordering on the symbol in LTSpice. I checked out of curiosity and the pin order for the netlist seems to match.
What errors / issues are you having? Are you getting an error when you run the simulation? Or just not the expected behavior?
Your triggering circuit looks at least a bit unconventional. Have you tried a simpler circuit?
The following users thanked this post: Faringdon
Online Andy Watson
« Reply #2 on: May 18, 2023, 06:52:50 pm »
Looks like you are trying to trigger the triac with a negative going pulse - which will be clamped by D1.
« Reply #3 on: May 18, 2023, 07:17:55 pm »
Sorry my bad....i hadnt sized the RC trigger cct correctly ...
