Author Topic: LTSpice Performance Tests  (Read 1182 times)
Offline udokTopic starter
  • Country: at
« on: October 04, 2022, 04:13:13 pm »
Hello,
I have uploaded a PowerShell script to test LTSpice performance (LTSpiceBenchmarkEricSims.zip).
The test files include the quasi standard test files bjtff.cir, mike2.cir, mux2.cir and more complex test files.
Please run the test and post the results or report problems here. The file Readme.md has more info.
I am specifically interested in Ryzen 9 versus Intel i9/i7 because in preliminary tests the results are very different (up to a factor 10) depending on the test case.
Best regards,
Udo
Offline AndyC_772
Re: LTSpice Performance Tests
« Reply #1 on: October 04, 2022, 04:25:00 pm »
LTSpice performance depends largely on the storage device to which the raw results are written. Are you using the exact same HDD or SSD in each case?
Online Ian.M
« Reply #2 on: October 04, 2022, 04:50:02 pm »
I hope this topic doesn't get shut down, but the LTspice XVII license does say:
5. Publicity. Notwithstanding anything in this Agreement, Licensee may
not use any trademark or trade name of Analog Devices or make any public
announcement regarding the existence of this Agreement without Analog
Devices' prior written consent. Licensee may not publish or provide the
results of any benchmark or comparison tests run on the Licensed Software
to any third party without the prior written consent of Analog Devices.
  • Country: at
« Reply #3 on: October 04, 2022, 05:06:35 pm »
I use SSD.  The performance should not depend much on the SSD speed (i hope at least).
Windows uses the RAM to cache the files, and the run time is much larger than the time needed to write the raw file to disk anyway.
Offline Simon
  • Global Moderator
    • Simon's Electronics
« Reply #4 on: October 05, 2022, 07:46:33 pm »
looks like you have breached it too in bringing it to our attention  :-DD, there is no stopping these lawers.
The following users thanked this post: Ian.M, Fgrir, SiliconWizard
