Author Topic: LTspice AND statement  (Read 4138 times)
Offline FaringdonTopic starter
« on: April 07, 2024, 04:40:45 pm »
Do you know what's wrong with the attached?
As you can see, its obvious what is meant, but syntax dumps it.
'Perfection' is the enemy of 'perfectly satisfactory'
Offline PlainName
  • Country: va
Re: LTspice AND statement
« Reply #1 on: April 07, 2024, 04:56:34 pm »
There are five opening parenthesis and only four closing ones.
The following users thanked this post: Faringdon
Offline SiliconWizard
« Reply #2 on: April 07, 2024, 10:12:13 pm »
Yes, damn syntax. ;D
Offline Zero999
  • 0999
« Reply #3 on: April 08, 2024, 07:36:13 am »
What are you trying to achieve?
LTSpice doesn't have an AND statement. Use the boolean operator &.
https://groups.io/g/LTspice/topic/50204515
Offline Shell Albert
« Reply #4 on: April 25, 2024, 06:33:48 am »
Haha, so interesting.  I never use LTSpice,  although it's small size and has many libraries built-in, but it's too simple.  I highly recommend you to use Cadence Pspice, powerful, complicated and popular.
