Author Topic: LED footprint without thermal vias  (Read 2082 times)
Offline ocsetTopic starter
« on: October 28, 2017, 06:53:07 pm »
Hello,
We are using the Seoul Semiconductor SAW09H0A LED.   They are dissipating  2.3W  each and are mounted on  double sided FR4 PCB of thickness 1.6mm and 1 Oz copper. The PCB sits on a heatsink platform.
Our PCB contractor has done the footprint as in the attached. (Red is top copper and blue is bottom copper)  The thermal vias are of diameter 0.65mm,  but  there are no thermal vias  under the actual pads of the LED.
The datasheet gives no guidance. Do you think that we could get away with putting 0.3mm vias in the actual LED footprint, with spacing about 1mm apart?
SAW09H0A datasheet
http://www.seoulsemicon.com/_upload/Goods_Spec/Specification_SAW09H0A.pdf
Offline DerekG
  • Country: nf
Re: LED footprint without thermal vias
« Reply #1 on: October 28, 2017, 10:33:10 pm »
Yes, but only if you have the board shop plate the vias shut (ie they will be totally closed). If you don't, the solder paste when in the infrared/vapour phase oven, will be wicked down the holes thereby degrading the heat transfer to the top side of the board.
Use a 0.2mm solder paste screen to deposit a reasonable amount of paste under the LEDs.
Also, consider using 2oz copper if you can for much better heat dissipation.
We have had a lot of production experience with SMD mosfets, even to the point of having x-rays taken of the resultant solder paste spread under under the mosfet heatsink & the above is what we concluded brought about the best reliability.
I also sat between Elvis & Bigfoot on the UFO.
The following users thanked this post: ocset
