Well, isn't that a question that Hyperlynx PI is supposed to help you finding an answer for?
![Grin ;D](https://www.eevblog.com/forum/Smileys/default/grin.gif)
And up to what frequency do you need 0,1 Ohm impedance? Chances are that you don't need an impedance below 0,1 Ohm up to 1 GHz, if you don't need your rise times to be significantly faster than roughly 1 ns (slow rise times down as much as practicable).
As a first guess you can add capacitors that have their self-resonant frequency at about your anti-resonance peaks. Any further action will depend on up to what frequency you need the impedance to stay below 0,1 Ohm. But again, a tool like Hyperlynx PI should give you a good answer by playing around.
