Author Topic: If you could only use one CAD suite for PCB design, what would it be ?  (Read 22472 times)
Offline Iliya
Re: If you could only use one CAD suite for PCB design, what would it be ?
« Reply #25 on: October 28, 2014, 12:28:22 am »
If it's regardless of cost, then simply get somebody else to do the design! Easy :)
The question really is too nebulous.
Get the tool for the job. No point in using a NC drilling M/C when a simple battery electric screwdriver with a hex fitting bit will do. Or even a hand powered bit. KIS principle.
Online Alex Eisenhut
  • Place text here.
« Reply #26 on: October 28, 2014, 12:57:25 am »
Hi all,
What is the most capable CAD suite for PCB design ? Regardless of cost and learning curve.
I've used SMartwork, Tango which became P-CAD, Pads 7.0 under DOS, something that ran on the Amiga, SciCards (which as far as I can tell was the first commercial PCB package?), Pantheon Intercept, Altium, PADS under windows, and Allegro.
I'd say overall Cadence Allegro for PCB, warts and all. I'd like to have the choice to use Altium's schematic entry, though.
Offline tggzzz
« Reply #27 on: October 28, 2014, 09:09:32 am »
KIS principle.
Actually it is KISS, which in English has two valid meaning depending on whether there is added stress :)
Keep It Simple and Stupid
Keep It Simple, you STUPID person
« Last Edit: October 28, 2014, 09:11:35 am by tggzzz »
Offline Iliya
« Reply #28 on: October 28, 2014, 11:23:41 am »
I was trying to be polite. The second S can offend and is often meant to!
Offline Wilksey
« Reply #29 on: October 28, 2014, 11:34:09 am »
 Horses for courses.
You don't work for Tesco do you?  :-DD
Offline tggzzz
« Reply #30 on: October 28, 2014, 07:40:13 pm »
Yup :)
Offline Iliya
« Reply #31 on: October 28, 2014, 08:58:48 pm »
Oops. Freudian slip or parapraxes.  However, if we were in France - Um Um  :P
Offline cloudscapes
« Reply #32 on: November 02, 2014, 02:14:56 pm »
been using diptrace since 2007. it has its quirks but I have no reason to switch.
Offline TunerSandwich
  • I kiss on the first date
« Reply #33 on: November 10, 2014, 04:27:36 pm »
It might be worth it to switch to the layout software that your supplier uses, in house.  For example, we are evaluating OrCAD (Cadence) right now, because a supplier for our new project uses it in house.  This would save us a lot of time and hassle in creating libraries/pads/etc.  Especially for completely proprietary parts.
A lot of it comes down to raw/total costs.  Is it cheaper/more cost effective to payout for licenses, to gain an existing library?  I suppose that is to be determined on a specific basis.
If the vendor supplied eval board contains the topology you want to implement....it might be worth it?
At any rate, I find it useful to talk to applications/engineering at various vendors, to gain insight into these things.  Sometimes (for us) it's not about what is "the best" (technically)....the bottom line usually boils down to the bottom line ($).
Fundamentally they are all CAD and if a major supplier/engineering firm was able to  use a specific package for development, then chances are it does "work"....
 :-/O
P.S. if I had to choose one, and only one, it would be whichever one has the largest support packages for the devices I most typically work with.....if the cost was no object and the dev times were infinite....it would be Dassault Systems.....the integration between mech and electrical design is amazing, and their simulations actually work (and integrate into mech physics).   Probably OrCAD for layout etc....
P.P.S.  if the company credit card was fully loaded and the moon was the target......http://www.solidworks.com/sw/products/details.htm?productID=2162
« Last Edit: November 10, 2014, 04:38:46 pm by TunerSandwich »
In Soviet Russia, scope probes YOU.....
Offline Layoutguy
« Reply #34 on: March 02, 2015, 02:55:22 am »
I've used the PADS layout platform for many years in a busy service bureau environment, and I'm very satisfied with the capabilities after nearly 30 years of use. PADS was a low-cost system when first introduced ~1986, but it's a bit pricey these days.   I used Racal-Redac systems for 5 years prior to PADS, and most of you wouldn't believe how expensive layout systems were back in the early 1980s!  Over the years, PADS software continually evolved and changed ownership several times, and it's now a Mentor product. Of course, PADS has its quirks & limitations, but despite evaluating several other leading brands, I have not been convinced to jump ship.  I don't know how capable the stripped-down entry versions are, but the top-end toolset manages the broad spectrum of complex board types we see.  Sounds like I'm promoting PADS, but I'll be the first to say that PADS is just one of the many capable platforms available.  They all have strengths and weaknesses. You have to make a choice and stick with it for a while, since database conversions between brands can be a hassle.
Offline DavidDLC
« Reply #35 on: March 08, 2015, 06:46:30 am »
These type of questions....
Unless there is a person that has used ALL of them, then that will be the right person to answer, other than that.... well just opinions.
David.
Offline DerekG
  • Country: nf
« Reply #36 on: March 08, 2015, 11:51:43 am »
Once you get used to use it (AD) , you will never be able to use any other tools.
This is opinion only, just as the poster immediately above correctly writes.
I use for Altium, Proteus & DipTrace, all for work.
Proteus is my favourite & Altium my least favourite.
I'm currently working through with Novarm (the developers of DipTrace) to truly bring their package into the professional arena.
As far as company insight into the future goes, Novarm is number one & sad to say it, Altium comes in last.
I also sat between Elvis & Bigfoot on the UFO.
Offline Warhawk
    • Personal resume
« Reply #37 on: March 09, 2015, 12:53:25 pm »
It is nice to hear that. I also like your inputs on their forum. :-+ It seems it is a small company with young developers and they should get in touch with some experienced EDA professional. I am wondering if any of those guys has ever designed some professional PCBs (besides hobby projects).
Honestly, I must say that after the first positive impression with Diptrace I can not get over some bugs or missing features (e.g. sheet connectors, PCB update from library etc.). There are also some bugs which were reported more than five years ago and still without any fix. For example copper pours and DXF export (for our CNC).
Offline DerekG
  • Country: nf
« Reply #38 on: March 09, 2015, 02:01:28 pm »
Yes, the two co-founders are Ukraine graduates with mechanical & electronic engineering degrees. They do rely on users who push DipTrace to its limits to learn what needs advancing next.
I use copper pours extensively & the update 2.4 last year provided significant improvements in this area. Perhaps start a new thread & point me to it & I will assist with working through any problems you are experiencing.
Online Bud
« Reply #39 on: March 09, 2015, 02:34:37 pm »
Then they better hurry up before their president burns them in the civil war.
Offline Warhawk
    • Personal resume
« Reply #40 on: March 10, 2015, 08:31:26 am »
Luckily a friendly Russian president may help them. The Czechs have a lot of experience with that from former times  |O :scared:
Offline DerekG
  • Country: nf
« Reply #41 on: March 10, 2015, 11:47:01 am »
For those who don't know, some of the best of Altium's programmers are also Ukrainian. The universities in Eastern Europe produce some of the worlds best programmers.
I've heard in the grape vine that some/a few/many of Altium's programmers are currently wanting to emigrate to the USA.
Offline Takto
« Reply #42 on: April 30, 2015, 01:04:30 pm »
David.
Exactly what I was thinking. How does it help to hear all these different opinions? There is no real answer anyway...
Offline Gribo
If cost is not an issue, I would use DxDesigner and Expedition from Mentor graphics. I have used it when it was called AcePlus, then VeriBest and now DxDesigner.
I am available for freelance work.
Offline tggzzz
David.
Opinions backed by caveats are valuable. For example,
  • "Mental Gruffics is complete and will enable you to do signal integrity planning, but expect to spend 6 months learning it and preferably have a sysadmin to care for it"
  • "CrossCAD is used by some large organisations and has an active community which is continually adding new features, albeit in an ad-hoc fashion"
  • "Vulture is widely accepted by vendors, but once you hit a limit your pocket is lightened"
will enable different people to concentrate/ignore different options, based on their needs.
OTOH, "I use X, and so should you" is valueless.
Offline jmarkwolf
Many moons ago I used to use something called Protel, haven't designed or made a PCB in years so no idea if it is about now, although someone did say it had changed names, I liked it.
Protel is called Altium nowadays. It also has a new spin-off called Circuit Studio (and Circuit Maker).
