Welcome to the furum
Not sure that you can.
Which version are you using?
Normally this is something you would set the trace width for to accomodate the current on each trace/net.
You also need to consider whether to use 1 oz or 2 oz PCB
Google "guideline for pcb trace width" to get guidance on trace current capability.
