Hi Guys,
I've finally come around to designing my first PCB for a discrete linear regulator I've designed. I have some experience in IC layout (Cadence Virtuoso) but non when it comes to PCB's. I've decided to use FreePCB as its seems very easy to use, and I a coworker recommended it. At the moment I would like to try and stick to that program.
Now to the question:
I've got a few large capacitors I'm using, which have up to 1mm diameter of the leads. So I understand its about 40mil (39.37), right? In that case what size of hole and pad I should use? Will 45/90mil be good? I was quite surprised to see that the RAD-709 footprint (capacitor with 7.5mm LS, and 18mm dia.) available in FreePCB has 28mil/65mil hole/pad size for these large capacitors, and I can't understand how its supposed to fit them.
I'm sure I'll have some more questions once I move along, but that is all at the moment.
Thank you.
