Author Topic: Gerber Parser?  (Read 3561 times)
Offline 741Topic starter
    • Circuit & PCB Design (small PCB quantities OK)
Gerber Parser?
« on: October 24, 2017, 01:06:02 pm »
Anyone know of either free Gerber manipulation software or a Gerber parser (C or Delphi/Lazarus)? It was a slow, painful process to create a panelised from multiple designs in KiCad.
I looked into gerbmerge, but it looks a bit painful; hardly intuitive or easy to use.
Also, out of interest, how easy would simple translate / rotate 90 degree operations be to implement on a Gerber dataset?
(I've got a copy of the file format, and it seems well set out, but also very long. I've onlly read a tiny fraction of it).
« Last Edit: October 24, 2017, 04:26:38 pm by 741 »
Offline ElektroQuark
    • ElektroQuark
Re: Gerber Parser?
« Reply #1 on: October 24, 2017, 01:10:04 pm »
Try this tool. It may help.
The following users thanked this post: kripton2035, 741
Re: Gerber Parser?
« Reply #2 on: October 24, 2017, 04:38:01 pm »
Hey, that looks more like it! Thanks.
Offline Mattylad
Re: Gerber Parser?
« Reply #3 on: October 24, 2017, 05:46:28 pm »
Why do you want to panelise the same Gerbers?
The fab house are only going to rip them all off bar 1 cct, do their front end work on it (etch compensation etc.) then repanelise it all.
Your effectively wasting your time, time that could be better put doing a good panel drawing that tells them what to do, which is something they can do in seconds with their front end software.
Matty
CID+
Re: Gerber Parser?
« Reply #4 on: October 25, 2017, 10:21:25 am »
Hi Matt
No, I panelised different 'Gerbers'! (In fact: I created several designs for IC adapters in KiCad, then I used File: "Append Board", finally I manually added tabs).
So, strictly I was working directly with design files.
However, it would be nice to be able to user Gerbers diectly, and to have some help with the layout from a dedicated tool.
Regards
Stephen
« Last Edit: October 25, 2017, 10:24:47 am by 741 »
Offline Warhawk
    • Personal resume
Re: Gerber Parser?
« Reply #5 on: October 25, 2017, 11:16:00 am »
@Edo: This looks great ! I wish I had this some time ago.
@741: Do Itead really charge extra when you have multiple designs on the pre-paid board or they don't care?
Re: Gerber Parser?
« Reply #6 on: October 25, 2017, 02:01:49 pm »
No extra charge  ;D
I checked with them first "is this OK", and they said basically "send us your files to check". It was OK, no problems.
I used 2mm router slots.
Main other thing is you ensure nothing can fall off and damage their equipment, result must be mechanically rigid.
