Author Topic: Drawing an arc in OrCAD (solved)  (Read 10018 times)
Offline Zero999Topic starter
  • 0999
« on: May 10, 2015, 03:32:32 pm »
I'm having problems with creating an arc shaped PCB in OrCAD. It's for an optical speed sensor and needs to fit round a shaft.
I've managed to create a semicircle but removing a semicircle from the middle to create an arc is proving difficult.
Is it just me or is OrCAD a pig to use? I can draw arcs in most drawing programs easily.
See bottom of the attached, for what I'm trying to achieve.
This was drawn using OpenOffice.org in a couple of minutes. I've spent several hours trying this with OrCAD and not had any luck!
« Last Edit: May 12, 2015, 10:52:52 pm by Hero999 »
Offline Alex Eisenhut
  • Place text here.
Re: Drawing an arc in OrCAD
« Reply #1 on: May 10, 2015, 11:52:31 pm »
What do you mean OrCAD? What they call "OrCAD PCB editor" that is actually Allegro?
  • 0999
« Reply #2 on: May 11, 2015, 07:52:50 am »
Yes, sorry should've been more clear.
Online nctnico
« Reply #3 on: May 11, 2015, 04:21:38 pm »
In Orcad Layout you have to force 3 line sections by extending the ends of the circular part. Once the inner circle has been drawn you can drag the extentions back to the intended size. Easy if you know what you are doing.
Offline Neilm
« Reply #4 on: May 11, 2015, 06:32:19 pm »
I admit I haven't had to draw PCB outlines in Allegro (they get imported from Solidworks) but can't you just draw a circle void on the PCB outline? Then merge the shapes and job done.
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. - Albert Einstein
Tesla referral code https://ts.la/neil53539
  • 0999
« Reply #5 on: May 11, 2015, 07:49:41 pm »
Thanks but I got there in the end, although it's probably a slow method.
To create the semicircle, I drew a circle and cut a piece off it. What's annoying is OrCAD always keeps the larger piece of the shape so I had to perform the cut in two operations.
To make the arc, I drew two semicircles, decomposed the shapes, dragged the lines about to make the arc, used the compose shape command to join them back together and had to do a z copy to put transfer them to the correct layer.
  • Place text here.
« Reply #6 on: May 11, 2015, 11:55:12 pm »
Board outline should be on the board geometry/outline layer, you just create a polygon shape and use the arc mode. You do see the option panel, right? Sometimes on dual monitor systems the windows go off-screen.
Cadence also enjoys slicing functions very finely when they create licenses. Maybe arc mode is disabled...
Offline Neilm
« Reply #7 on: May 12, 2015, 07:45:30 am »
By default, those option panels are not shown so it can be easy to miss. On my system at work, it selects the line 45 degree option by default. I can't imagine Cadence would disable something so basic.
  • Place text here.
« Reply #8 on: May 12, 2015, 10:50:10 am »
By default, they're all there usually. If not, go to view -> windows and click them back on. If they're off the screen as can happen with laptops when docking to another monitor configuration, go to view-> reset UI to Cadence default, that'll marshal all the windows back to being docked to the main window.
If still no go, just draw a shape rectangle and use the shape editor edit boundary, you should see arc in the pop menu.
  • 0999
« Reply #9 on: May 12, 2015, 10:52:17 pm »
Yes I did have problems with the options window not showing but sorted it out long before I encountered this issue.
Anyway I think drawing the semicircles separately, before joining them up is probably the easiest way to do this. I need to accurately control the size of the arc and it needs 0.5mm chopped off the flat sides as the two arcs will be fitted round a collar and I need 1mm clearance.
  • Place text here.
« Reply #10 on: May 12, 2015, 11:02:08 pm »
The little arrow to show if the window is maximized is quite small. But I can draw a perfect circle without ever using circle or arcs.
"But how can you do this Alex!?" you ask excitedly.  :scared:
Look at the manufacture -> dimension -> fillet command. Enter the radius you want, click on two intersecting line segments. There you go.  :popcorn:
Only valid for line segments, not shapes.
