I put PCB in quotes because if it's by hand,it's not really printed any more.
Hope this is the right place to ask this question.
I'm looking at redoing my environmental control system as a single board solution but I just want to drill my own holes and run wires and do it all manually, as it's just a 1 board deal so not worth getting the equipment/products to do a real PCB or to get one done professionally. Eventually I'd like to, but for now no. My current solution is a DIN rail on my server rack as cross connect and the arduino and relay boards sitting in a little plastic box on a shelf below it. Not easy to work on.
What is a good and easy to obtain material I can use to make a PCB from scratch? I was thinking thin plywood but not sure if I want to use something combustible... just in case. (this is all going to be low voltage stuff... it might see 24vac for stuff like the furnace thermostat). I'm also in Canada, so don't have access to as many of the fancy places the US has. I'm thinking something I can just get at the hardware store that is easy to drill, non conductive, and fairly heat resistant when using the solder.
I looked into perfboards, but issue with those is the holes don't always work for everything, such as relays. The centre pin of a relay does not match up. It's also hard to find big ones.
Open to suggestions.
Also, is there any places in Canada that will do a single PCB for a fair price? I'm still open to actually learning KIcad or other software and doing a real PCB, but I just don't think it will be cheap to do just one. I may potentially make this a project that I release to the public though so it would still be neat to go through the process. To keep things simple and cheap I'd probably go with through hole stuff and solder it by hand at first so I'd need literally just the pcb with holes and traces and that's it.
