A few more points..
DEX sets up vias automatically? Does it have a sane method to tell it 'no, you can't do a buried or blind via' on a board wide scale?
And how exactly do we do buried vias on 3 layers?
Here is the option.
Okay, not that I can see most of the box and figure out how it works. But okay.
You can't have a buried via on a 3 layer board but you can have blind vias. I thought you would realize that.
But you said buried, not blind. You see, I do realise these things, I've actually designed and made boards!
May I make a suggestion: Perhaps if you tried AutoTRAX you may then be able to make more valid contributions.
Download from http://pcb.software
Sorry, but the current version costs money and I already said I'm not paying you a penny. It's nothing to do with the tool, either, it's
you. And yet I'm still here spending a little of my time trying to help you improve your software for others.
Also, I am not going to spend days learning a tool I'll never use because you refuse to actually discuss things.
See this. It's off by default so all vias are through board.
How does that in any way answer my question? Let me repeat it again.
Why would you want a checkbox to extend a buried via into a blind via or a through hole when you could simply specify a blind via or a through hole?
