I really wanted this to be good, and I'm sure it can be, and I am sure it will be if only Iliya would stop being bitchy about free_electron's typing skills.
He's provided some amazing feedback of things that NEED to be improved, crucial for me is the ability to manually tweak the solder mask. Until that's fixed it's not worth my while doing anything with this.
See attached.
This is far more than tweaking.
I will check that out tonight. Remember i am trying to do this in the footprint editor. Not the pcb editor . Don't know if it makes a difference.
I could not see a soldermask layer in the layerstack inside the footprint editor.
All i found is an entry field that seems to set a global soldermask expansion. I need to be able to set expansion per pad. The mask rules need to be tied to individual pads. For a single footprint some pads may need larger opening than others. All i found is an entry field that changes all of em. And that is insufficient.
I have written a bunch of bug reports. When i click send it takes like ten seconds and then the bug report window closes. There is no notification anything is wrong nor a confirmation they were received. I can't help it if they don't leave and dex doesnt tell me if it has trouble sending. Nothing i can do about that, that's your end of the stick: you wrote the code, i expect it checks for succesfull delivery. If not : bad programming on your end. Dex doesnt tell me whether it went through or not.
As for comments that are hard to follow : they are screen captures . How much more clear do you need it to be. You even see my mouse movement. You see where i click and what i do and how dex responds. And you have a written script including time markers. It does not get any clearer than that. Do you need me to sit next to you and show you ?
I dont understand why you only seem to be able to fix a bug if it is reported through the bug reporting tool. Even if i wrote a letter to you you should be able to fix it.
The videos clearly show step by step what i do and when problems occur.
I am growing tired of this. Its like herding a blob of jello...
