Author Topic: DEX eval by free_electron  (Read 336957 times)
Offline Iliya
Re: DEX eval by free_electron
« Reply #925 on: April 26, 2015, 07:15:42 pm »
Hi Vincent
I am prepared to work with you to extend DEX so it has Technology rules throughout. The user would be able to setup and switch rules for a design.
However it is best to do this offline, but keeping the forum updated. Are you up for this?
Technology rule would also include DRC.
Regards
Iliya
Hi Ilya, I hope you don't go off-line with it. The discussion is very interesting and illuminating.
I am learning things myself (I design PCBs as part of my job). It is interesting to see what features are
available and useful in the higher-end CAD packages.
John
I have not had any files yet from Vincent.
Offline Iliya
« Reply #926 on: April 26, 2015, 07:17:09 pm »
a nice thing to have would be an automated tool that, for a via that is defined as testpoint, puts the net label on the silkscreen.
that is how i create labeled testpoints. let the software do the assignment , then i simply highlight the points of interest and i draw a little circle around the via and put the net name down.
What font height would you use?
User definable.
I appreciate that, but I will try get a feel for actual font sizes people are using.
Offline tautech
« Reply #927 on: April 26, 2015, 07:19:16 pm »
User definable.
60 mil is a good starting point.
Online nctnico
« Reply #928 on: April 26, 2015, 07:48:21 pm »
I mostly use a height between 0.8mm and 1.2mm. It doesn't need to be readable; I usually put the text under the SMT components because there isn't enough room beside the components. However on many boards I have component references in different font sizes. Fuses, connectors, switches usually get a much bigger component reference.
