Is it just me or you and your comments are being ignored as well as mine ?
Not sure if it was my post that inspired Iliya to change the way the wiring on the schematic works, but i see that as a kind of response. It really works nice now. I also should mention, bashing DEX is also not my intention at all. As many others have written, i think it has a huge potential, but also a few very serious problems, which i'm trying to show on these little clips or reports.
That leads me to the next test i did: mentioned already copy/paste problem.
I wanted to create s few basic components from scratch, started with a simple 0805 resistor. I believe i succeeded. Then i wanted to create a schematic with a large number of these parts to see if there are any potential problems and maybe replicate the behavior i noticed in the led driver example.
As you can see, everything worked fine:
That got me to think, hey, maybe there is something wrong with the stock parts library, maybe they were imported, somehow got corrupted during the many updates, worth testing.
I recreated the schematic with the stock resistors and the problem with pasting the buffer showed up:
(<-i think this clip was too large, "img" does not work). I even repeated the last copy/paste action to see if it works the same. Yep, it did.
To verify that further i created another component: an electrolytic cap and started to multiply them again:
Well, the problem still occurs. At some point, when i hit the ctrl+V the buffer is immediately pasted ontop the originally copied section, makes a total mess over there and only a few wires, sometimes pins are floating and can be moved with the mouse cursor. This also creates a previously seen problem with copying a part ("Cannot copy muli-part symbols").
Hope that test will help Iliya to fix the problem and push the Dex one step further.
