I did NOT import it. I created the schematics and parts direct from datasheet and the TI pdf.
Okay, so you copied it.
As for not even started then what is in the screenshots?
An imperfect copy of a schematic and an autoplaced and autorouted board layout which can't work?
Somehow I doubt you have even started your design, will it ever appear?
Okay, let's put up one I've made (An FTDI board, and an adapter to go with it), one I'm working on (an FTDI cable), and a nearly finished prototype related to the previously mentioned project.
Are you done attacking those trying to help you, now?
What part of not finished do you not understand?
I am not attacking you, it is really the other way round.
Are these the complex six layer boards with dual row QFNs and controlled impedance that were were talking about?
I look forward to seeing the schematics so I can show you how to do it in AutoTRAX.
The schematics must be done otherwise you would not have gone to all that effort laying out and routing the boards. I did mine quick by locking a couple of parts in place and runnig autolayout and autoroute. This took me < 1 minute.
So if you can make the schematics available I take a look, copy them into DEX and get back to you tomorrow afternoon. Can't do it in the morning, I'm off out on the bike.
I don't want the PCBs, I will do them myself so we can compare.
