Author Topic: Any way to simulate MT3608 (spice)?  (Read 3476 times)
Offline shapirusTopic starter
  • Country: ua
« on: December 31, 2023, 10:18:19 am »
There seems to be no Spice model for MT3608 at all.
Does anyone know an alternative IC that is similar to MT3608, ideally being pin-compatible, for which a model would be available that could serve as a substitute for simulation?
Offline Doctorandus_P
Re: Any way to simulate MT3608 (spice)?
« Reply #1 on: December 31, 2023, 01:08:18 pm »
My first guess is that manufacturers of cheap chinese stuff don't bother with spice models.
A second guess is that simulation would not be very useful. Parasitic properties due to PCB layout and of the used passives probably have an important influence on the end result.
  • Country: ua
« Reply #2 on: January 01, 2024, 10:14:04 am »
Yeah I kind of figured that out. That's why I'm looking for something that might be compatible and have a model.
That's clear, I understand the limitations. Main idea is not to simulate it down to fine details to see how a real PCB would behave, but rather to avoid setting the "exclude from simulation" flag on a bunch of components and adding makeshift substitutes like the voltage source spice primitives instead, which won't even be sufficient in case when I to use e.g. a variable output feedback divider.
I usually try to create a single nice schematic that works as such, works for simulation, and works for PCB design. Often it is quite feasible (for example, with MC34063A, if we speak about switching converters).
