Hello,
TL;DR I don't think the footprint I downloaded looks right, need more gold standards to compare against.
I made a PCB in EasyEDA but a higher power wanted it done in KiCad so I did it in KiCad. In EasyEDA I could pull the footprint and 3D model from the selector thing from LCSC and it was fine. But for KiCad, I picked out
https://www.digikey.com/en/products/detail/amphenol-icc-fci/ICD15S13E4GV00LF/1536418 and got the UltraLibrarian stuff. Go to put the 3D model I found in, and it only lines up upside down. I looked at my Basys3 boar, and it has the middle row shifted to the left if you look at it like this:
(connector)
(first row)
(second row to the left)
(third row)
(PCB).
So I'm thinking "ok, must've spec'd an upside-down connector." Found a GitHub project with this board:
That's what I want. They go to the left. I look at the BOM... as far as I can tell it's the one I picked without the extended nut things.
https://www.digikey.com/en/products/detail/amphenol-icc-fci/ICD15S13E4GX00LF/1536501The difference is GX vs GV, but the drawings say
GX->HARPOON+INSERT UNC 4.40+METAL BRACKET
UV->F.SCREW LOCK UNC 4.40+METAL BRACKET
So the GitHub picked the GX (pdf says nothing about GV, I have to assume it's the same as UV. I notice in the footprint of mine
https://app.ultralibrarian.com/details/7174734F-C5BA-11E9-AB3A-0A3560A4CCCC/Amphenol-ICC/ICD15S13E4GV00LF?ref=digikeythe pin 1 is in the top right. Whereas on the GitHub it's the bottom left. As if the footprint is rotated 180*, but the rest of the connector looks fine. I've been trying to find other footprints. I found this
https://app.ultralibrarian.com/details/FF5850C5-103E-11E9-AB3A-0A3560A4CCCC/TE-Connectivity/5177802-9?ref=digikeyand it's like what I'd expect, but it's a $14.62 connector, so... even if it is correct it's too much for a VGA connector.
I tried finding the one from LCSC (which is $0.36) and it's here
http://en.connfly.group/product/xVkr=EusQssAN0gN=Aos=mU+UrVkR9kqEAN0gN0IWqcNB+A. Can't find the footprints/models even though they show up in EasyEDA. The PDF
http://outer.connfly.group/static/upload/file/pdf/DS1038.pdf shows that bottom view again. Does this mean the UltraLibrarian footprint is upside-down? I am not confident in my "this looks wrong" detector
to be able to tell. If anyone has used VGA connectors recently, please help me out. I really don't want to find out I put it in the PCB upside-down.
Thank you.
