- click on the move command
- click on the group command
- draw a rectangle to select the group of objects you want to move
- while keeping the ctrl-button pressed, right-click with the mouse somewhere on the group
- drag the group of objects to another sheet (it's located on the left).
In case the scrollbar with the sheets isn't visible, right-click on the toolbar and activate "sheets".
