Hi All,
After trying Kicad on a Macbook, and quitting rapidly once I realized it was just impossible to use with the trackpad, I switched to Eagle, and find it quite usable, despite the non -Mac syntax.
Once you start to understand the philosophy of the software for selection, things start to behave better, and
you get the feeling that you can do a lot with Eagle, especially because of the scripting capabilities.
But I encounter this error in the ERC check :
"More than one OUTPUT pin on net SDA"
It seems to me that it is perfectly normal to have several connections to a SDA bus line.
Do I miss something ?
Why is Eagle complaining ?
How can I remove this message ?
Thanks.
