below is the schematic for a "blast" converter that can somehow "blast" the input voltage by more than 27X!!!!!
[ Attachment Invalid Or Does Not Exist ]
I tried running this exact circuit on my breadboard with a 12V 2.5A power supply and my 1kV meter. when I ran it, my meter (it was on 1kVDC mode) read 324V. there is a problem with this circuit though, you absolutely cannot short the MOSFET (things like reading current) but, since this is a boost converter and not a buck converter, I think the output current should be the same as the "outside" current (the current that is still in the
breadboard "bus" while the circuit is running is, in this case 2.3A) but wouldn't that mean the output is 745.2W?!?! but the input is 30W max! is there something wrong with my meter, or something wrong with me? or did I just create a super-stepper?
