Inductive wireless charging for phones and similar small devices, good idea, especially for people who have limited dexterity, I know quite a few people who struggle badly with conventional phone charger cables to the point that wireless charging is a must have when buying a new phone.
I'm thinking more along the lines of a lack of connectors to break.
You can make magnetic connectors, like what Apple had a couple years back, that´s an easy one
Gold platting can make them corrosion resistant, they can be made easy to clean and magnets self-latch so no worries there.
With inductive charging your losses can be high enough, especially when you are end charge, plus to actually use the phone you move the phone,
away from the charger, that stops the charger from supplying power to your phone, consequently start draining the battery so this could lead to more
charging cycles, which in the end is going to kill your battery faster. Cause you can imagine just that, you leave the phone charging, middle of the charge
someone calls you, you pick it up, stop the charging, speak for 5 mins, drain the battery according to your reception in the area, put it back on the charger
and you just induced a new charging cycle. That wouldn´t happen with a cable most of the times, you just pick the phone, answer, talk, close the call
all when your charger is still plugged in.
I would assume here that most of the phones ( I know it from mine ), use a load share charging system, so when you plug in the charger, the charger is
providing power to the phone and the rest of the current it can deliver goes to charging, and if the load is that heavy (or the charger that bad for that matter)
all the current of the charger is going to the phone while your battery is also being drained.
And since most of the batteries in the phones, nowadays, are build into the phone and can not be user replaced, that only leads me to believe that the OEMs
are willing to make the phones more and more of a disposable good. It´s one thing making the phone break easily when you drop it, it´s another when you
intentionally try to reduce its lifetime.
See fast charging for example, LiPos are happy with 1C charging, most battery manufacturers say that it´s ok to do more than 1C charging but you are limiting
the life of the product and next thing you know is fast charging. Would the batteries be user replaceable, I wouldn´t consider to nag about it, but most are not.
Plus for all the fast charging products that exceed 1C charging there should have been a warning, If you use fast charging you are considerably limiting the
life expectancy of your battery, do you want fast charging or not? But.... there is non.... maybe in the fine print, but nobody reads that before it´s too late.
So yeah, I do kinda think wireless charging is a gimmick, and not only from the efficiency point of view.
