Very interesting:
The all-natural elemental diode is in a formula base of forty-seven different energy frequencies. It is molded into different strengths and forms to be worn on the body or placed on devices that emit electromagnetic radiation. A diode is defined as a device with a two-element electron tube or semiconductor through which a current can pass in only one direction. The natural elemental diode’s energy current moves in one direction, giving a positive spin of energy. The elemental diode also acts as a rectifier by keeping the body’s energies and meridians in perfect balance.
so if I wear it on the wrong side my energy will be lowered?
I accidentally washed my Personal Diode. Is it ruined?
We suggest you place the diode in the sun to recharge its energy. Place in direct sunlight for 30 minutes on each side.
They invented a rechargeable diode.....
Best regards
