Came across this beauty:
7mm Black Silicone with Synthetic Jacketing resists heat, oil, and abrasion. A combination Kevlar Helically Spiral Wound Core at 350 ohm per foot resistance delivers greater spark energy, while improving power, idle, and fuel efficiency.
That's higher than typical nichrome wire used in heating elements, so it must be more efficient.
Then again, a certain maximum power transfer theorem may have something to do with this.
8mm Black Silicone and Synthetic Jacketing resist heat, oil and abrasion. 500 ohm per foot resistance delivering spark energy, while improving power, idle and fuel efficiency. A combination Kevlar Helically Spiral Wound Core conductor for greater strength and durability that suppresses Electro Magnetic (EMI) and Radio Frequency Interference (RFI).
Even more resistance, so much higher efficiency! And magic EMI/RFI suppression spiral, so no need for any pesky shielding or ferrite beads. Ride around those high-power TV/radio transmitter towers without Fox News interfering with your ignition timing!
All wires fire intermittantly no matter what coil or ignition you may have. That is why you see carbon on your plugs. ThunderVolts have a solid stream of fire power resulting in more horsepower and more mileage. Your bike will start and run better than ever before!
PACK SOME HEAT with our new 9MM Firepower spark plug wires. Black wires feature Silver 9MM Gun Boots. These are the hottest wires on the market today.
All wires fire intermittently no matter what coil or ignition you may have. That is why you see carbon on your plugs. Our 9MM Firepower wires provide a solid stream of fire power eliminating the carbon on your plugs. This results in more horsepower, more torque and better mileage. Your bike will start and run better than ever before! They are compatible with all Harley ignition systems. You have a choice of Custom Fit Sets for your Harley model or Universal Sets where you terminate to your desired length. All Taylor/Sumax wires are 100% made in U.S.A.
I thought it was the spark plug which was meant to "fire" and not the HT wires.
From memory, normal suppressor type spark plug leads were in the region of 10 to 15kOhms, so "350 Ohms/foot" sounds insignificant in comparison.
The ones manufacturers fitted were made of some woven carbon crud.
(It looked like they used string then burnt it.)
The horrible stuff would fail if over flexed, or even " if you breathed on it".
Faulty leads ranged from 50k to 500k.
The fault process seemed to involve small sections of the cable going open circuit, so there were a series of "mini sparks" along the lead, which seemed to "semi-repair" the opens, at least as far as testing at the low voltages produced on a multimeter Ohms range was concerned.
The very high resistance leads did cause misfiring, & a symptom of this fault was burning of the spark plug
connection where the lead plugged onto it.
One place sold "inductive" leads.
From,what I could determine,they were still made of "burnt string", but the individual strands were sheathed in some kind of brittle plastic.
The whole lot was then wound into a helix.
I tried them,but they didn't seem much better.
Please excuse any grammatical errors, but I am still experiencing the delights of editing on an iPad!
