In summary, your several last posts, seem to be saying, you believe in free energy, and know how to make such a device, and have patented it (patent pending, mentioned considerably earlier in this thread), as it is YOUR invention.
It just so happens, to apparently break a number of laws, experiments and hundreds of years of experimentation and theories in physics and/or mathematics and/or probably other subject areas.
Example (emphasis is mine):
In a self sustaining dynamo this energy can be extracted without interfering with the primary plasma current around the toroid.
The laws of inductance are clear, it does not break them. The reverse of the inverse square law that is common between all forces produces the square law for the inward wave. It is called the Theta-Pinch or Z-Pinch. The Square law of electromagnetic waves produces an exponential wave peak on the z axis of the coil in 3 dimensions. Attached again.
[/quote]
https://www.sciencedirect.com/topics/physics-and-astronomy/theta-pinchThe theta pinch is generated by a fast-rising azimuthal current in a single-turn external conductor that is wrapped around the plasma tube. This produces an axial magnetic field that compresses and heats the plasma. The SCYLLA theta pinch, developed at Los Alamos in 1958, was the first magnetic-confinement system to produce really hot fusion plasmas with neutrons from thermonuclear reactions. The pulse duration of a theta pinch is very short, typically about 1 microsecond, but even on this short time scale plasma is lost by instabilities and end losses. Attempts to stopper the ends with magnetic fields or material plugs and by joining the two ends to make a toroidal theta pinch all failed. Both the Z-pinch and the theta pinch are inherently pulsed devices. Even if all the problems of end losses and instabilities were to be solved, a fusion power plant based on these configurations would be a doubtful proposition due to the large re-circulating energy.
[/quote]
I wonder if it would be more of a viable method of extracting energy if you made use of that re-circulating energy?
You seem to put to much of your focus on the source of power, and forget to think about the energy conversion, every time energy is converted from 1 type to another, energy is lost. Focus on the energy required to produce the self sustaining dynamo. And the extraction of energy, ie which system, heating water into steam, or the non linear dynamics of plasma, will ultimately create a larger pressure gradient we can convert into electricity?
If heating water was so efficient, it would drive the wheels of your car.
