The logic between the antepenultimate and penultimate sentences of your reply is unclear.
Further details on tidal and non-tidal currents are found in paragraphs 913 to 922 of Bowditch.
There is a sinusoidal wave pattern of loops and nodes that occur inside both larger high tide waves. This is a fixed sinusoidal wave that rotates at the same speed as the planet. The position of each loop and node is fixed to a surface location. Ie Broome and Darwin, but you will find the same pattern exists along many of the east to west coastlines. Likely some north/south coasts as well. You are looking at the maximum height of the tide during the same high tide. Its best to do it on a spring tide but it can be clearly seen on every tide if you know what to look for.
Once you see the pattern of loops and nodes that exists across the Timor Sea, i added a sinusoidal wave to the graphic to make it easier to spot it. You can also see the same mechanism in the ferro fluid above it.
You will also notice this pattern across many other coast lines. The South China sea, North Taiwan has a node of under 1m while opposite it in Fuzhou it has a loop of 5m, Shanwei has a node of under 1m. Then it starts to rise again and that is only todays tide. I dont think i need to looking for the spring tide height difference.
Unless you remove the magnetic field lines of magnetism in your head and replace then with a magnet wave functions, such as the hydrogen atom from quantum mechanics you will never understand the 3 dimensional motion of Electromagnetism or the Plasma Universe. My spelling may be garbage, but the terms i use are specific. I have been mergering current terminology with 3 dimensional terminology in the hope you will natureally start to view magnetism from both the dipole and quadrupole perspective.
If you really believe the energy in a transformer core is being past by magnetic field lines with arrows on them and not a 3 dimensional wave such as that of the electric and magnetic wave measured by oscilloscopes in the primary that created the "field" in the first place and secondary winding that is harnessing it.
I previously showed some graphics of multiple hydrogen atoms wave functions side by side, its the simplest and current best model of the magnetic effect around all quadrupoles such as the Earth or Sun . Until you view these lobes over 2 dimensional maps you will not see the full picture. This is because as your observer enters the red lobe and looks backward the colour changes to blue, my reply to you a few nights ago explained this in detail.
The electromagnetic laws can be understood at a Quantum level by simply placing your observer inbetween 2 geosynchronous wave functions. You will quickly notice that the stronger dipoles are causing the electrostatic effect (like poles repel) and the quadrupole which must be offset N to S in every possible quadrant. When all forward facing dipole are compressed by acceleration such as accelerating Plasma, we find the electrostatic force remains the same as both dipoles compressed or expanded evenly, however the quadrupole inside the forward facing dipole have a higher energy density than the rear quadrupoles inside the rear component of the dipole. This is how Coulomb's law works at a quantum level. This differential level of energy between the compressed quadrupole and expanded quadrupole is measured by differential equations. I believe i have already explained the quantum difference between A.C and D.C.
