I thought it would be worth explaining a few points from section 5 of the non linear dynamics paper.
The total torque is balanced by the non-stationary part of the inertial torque
Torque is produced in a plasma toroid by the rotation of the quadrupole lopes inside the stationary dipole. This in electricity is DC. In DC the wave function of the atom is rotated along the poloidal axis of the wave. Ie the direction of current. This torque produces the right hand rule and is caused by the degree offset in the trajectory of the wave that is controlling the atomic structure of the conductor. The degree of the offset between 2 atoms means that 1 set of quadrupole lopes are offset to the next by the trajectory of the wave. Since it is inevitable that the lopes are opposite in ever plain any rotation of 1 atom sends a retarded rotating wave along the conductor. Then each wave peak of which is called the electron and termed negative.
Red colorshows positive values, where the torque enforce the fluid element to move in the posi-tive poloidal angle direction,
The poloidal angle direction is the tracjectory, when they say positive they are saying the particle is spin up.
blue color shows negative values, where the torque enforce the fluid element to move in the negative direction
As ive been trying to explain, the direction of rotation or spin direction is the master of all opposites. The colour, pole or value we place on the direction the wave is spinning/travelling is just that, our perspective. We have to take into account that the opposite observer views every colour, pole as opposite to us at any given time, but only some values depending on their orientation.
When i used the reference -1 + -1 in another form, i was taking about an opposite observer plus an opposite orientation flipping what is seen twice. It changes how everything looks in terms of positive and negative, and we need to understand that for mathimatical reasons. If we look behind us that is what we should see, which means that is what 2 parallel particles see of each other.
In the flow-suppressed phase (phase A), the magnetic island has a finite phase differ-ence with respect to the external perturbation.
The quadrupoles cant get out of alignment to much, the compression of external laminar flow contains the magnetic island. This is differential equations at work.
"In the nonlinear rapid growth phase(phase B), the magnetic island shifts in the poloidal direction so that the displacementsof the O- and X- points are different"
Here we have the dipole of the atomic wave function shifting in the polidal direction. This is the equivalent of A.C. where the rolling over of the stronger dipole produces a larger change in the magnetic and electric field.
Since this is called the rapid growth stage, we can see how this has a repulsive force between the atomic wave function. In electricity we say anti parallel current repels, while In plasma we say non linear plasma expands (explosively according to this paper)
So we can say that not only does the plasma reactor produce a self sustaining dynamo. It also has the ability to extract an explosive pressure gradient on an entirely different induced reusable medium.
Ie, it uses no fuel. Its Energy Source (fuel) is the self sustaining dynamo.
