Nikola Tesla's inventions and promotion of polyphase alternating current was a great step forward in electrical engineering.
Like other geniuses, some of his work late in life was not so fruitful. https://www.forbes.com/sites/alexknapp/2012/05/18/nikola-tesla-wasnt-god-and-thomas-edison-wasnt-the-devil/?sh=4adf64b71a21
Newton spent too much time at the end of his life interpreting the Book of Daniel--some think this was a result of inhaling too much mercury.
Einstein's famous failed late work was the development of a Unified Field Theory.
Hi Tim, Tesla's later idea may have not been fruitful. Although what path would he have taken us down had he been well funded by the patent he gave up the royalties too? I believe that was an unfortunate mistake that cost humanity a great deal. The words he left behind (to me) shows a genius beyond that of any other man in history.
If you only knew the magnificence of the 3, 6 and 9, then you would have the key to the universe.
In terms of understanding the Plasma Universe, this to me meant that if you use a clockface to plot the trajectory of multiply helical waves travelling in parallel and say that 3 is 90° around the axis, 6 is 180° and 9 is 270°. Then you say: the sine wave of the electric field is between 12 and 6 o'clock and the magnetic field is between 3 and 9 oclock. This mean that 12 is positive or north and 6 is negative or south. While 3 is north in the magnetic field and 9 is south. The the value of positive or negative depends on which side is closest to you so we have a small issue already that needs clarify because north and south cant change.
This is going to get long, i do apologize.
The 1st thing we notice is; that in the magnetic field 3 and 9 are always next to each other if the 2 waves are travelling in the same direction and the pattern repeats regardless of which location the particle is at around the wave. This is why 2 parallel current attract, because the opposite pole is always next to each other. Obviously travelling in the opposite direction the 2 9's are opposite and they repel. (NON LINEAR PLASMA)
The 2nd thing we notice is; if we rotate our view around a helical wave we see them spin down at 3 oclock and up at 9. While the 2 observers looking end on at the wave view it as clockwise in the direction of travel and anti clockwise look at it coming toward you.
The 3rd thing we notice is; when the 2 perpendicular observers view an ion or electron wave peak spin around, at 9 o'clock the observer looking across from the 3 oclock position views spin down while the observer outside of 9 has spin up. When at 3 o'clock the particle is spinning down for that observer and up for the one looking across from 9 o'clock. (use a mirror and spin a ball)
The 4th thing we notice; 2 observer rotating with the particle, 1 above the axis but below the particle and 1 outside, view the spin direction as opposite constantly, if our observer is orientated head clockwise then at 9 and 3 the particle is spinning up for the outside observer and down for the inside.
The 5th thing; to the 2 observers in the same orientations 12 is positive and 6 is negative for the electric field. In the magnetic field the 9 is positive for 1 observer while the 3 is positive for the other. While for the rotating observers the particle remains at the same height above the axis and the negative moves around always at the opposite location.
The 6th thing; to the axis of rotation, or common axis between the magnetic field and the electric field of the wave no negative value exists to this observer, for now lets call him the one eyed monster. Only height above the axis can be calculated from his position but he always views the underside of the wave (negative or electrostatic force or a south pole). That's why our current understanding of gravity has no replusive force.
This all means that; what is positive to 1 is negative to another, but when one views north the opposite cant views south because that was predetermined, and when orientation is flipped so is the direction of spin but not the value or field.
When considering a toroid, the clockfaces turns around due to the change in direction of travel, to the same stationary observer. 3 remains on the outside and 9 on the inside. Yet 12 and 6 stay put. This means South poles faces each other to the center of the toroid for the magnetic field, which is correct if we wrap maxwells straight wave around the toroid. Since we valued that location as negative we have 2 negatives facing each other above the polidal axis of the toroid. Hmm Maxwelll we have a problem, we have a new one eyed monster and he has 2 negative values above him, he cant be the same as the last 1 eyed monster who couldnt see negative, that are still some how above him, Do 360° of negative waves to the first 1 one eyed monster become positive to the second, and then does it matter if they add or multiple? They did not oginate from his axis and he view the wave peak. He still cant view negative from all angles.
-1×-1=? Im no mathematician but an exponential wave peak makes it sound like them bad boys multiple. I will refer you to multi graphs already posted mapping the strength of the energy from a coil. That is why we find a Z pinch at the center of a toroid or a pole at the center of a coil. The polidal axis....vs the equatorial axis. (posted by someone who found it elsewhere) i did make graphics on this that you are welcome to go look at again. Everyone kept asking for maths and i told them specifically, there is no negative to a wave in 3 dimensional space and everything is a rotating wave in a 3 dimensional universe.
I could go further down this path into quantum mechanics, its long enough i know but i seen some other cool Tesla quotes that i want to add.
All that was great in the past was ridiculed, condemned, combated, suppressed — only to emerge all the more powerfully, all the more triumphantly from the struggle.
Let the future tell the truth, and evaluate each one according to his work and accomplishments. The present is theirs; the future, for which I have really worked, is mine.
I don’t care that they stole my idea … I care that they don’t have any of their own.
So astounding are the facts in this connection, that it would seem as though the Creator, himself had electrically designed this planet…
What one man calls God, another calls the laws of physics.
I perfere to believe in the good in people, its time to get rid of the one eyed monster, and bring back GOD.
Maybe it just means looking at things from more than 1 perspecfive in life and in physics. If this makes any sense to anyone then i look forward to your replies and i hope you will support the idea in anyway you can. It doesnt need to be money, sharing and debating it elsewhere is the backbone of what science is suppose to be about. If you cant do that, then can you at least give the character assassination a miss. They are accusations that couldnt be ignored and quite frankly any man that would not stand up for himself after being called a bot and a liar is to weak to even be an inventor. They wouldnt survive the failures and i can tell you that solo sailing teaches you a lot about not giving up.
If you dont understand and want to, all i can suggest is going back and looking at all the graphic starting with the helical wave coordinates; understand the magnet and the electromagnet; how the exponential wave peak is induced into the conductor as a wave though the windings at 90° and figure out how Maxwell used the frame of reference for the moveable observers. The larger the angle of the trajectory, the greater the resistance. To achieve superconductivity the atomic structure must allow for the 1.1° trajectory. I cant make it any simplier im afraid so i hope you get it eventually because a double helical toroid creates superconductivity and the z pinch is the exponential wave peak of that energy, it naturally forms with a quadrupole. You dont need to believe me because im going to power the future with it and you will see it. It will be more fun and a lot faster if i get help. You could use it as an oppertunity to see if you're goverment really give a shit about the climate.
