Have you, at least got a degree (or above) in Physics (or closely related subject) ?
Alternatively, what is your highest academic achievement, within the field of Physics ?
At least one of your answers in this thread, would seem to indicated, a significant lack of knowledge and understanding, as regards Physics (and probably Science).
Alternatively-MK2, have you done any significant work, within the field of Physics (and similar). E.g. Made an experiment, which tests out a complicated Physics phenomenon, ideally with written up results ?
We have already had that discussion. Degrees mean nothing, ask Simon it was him that said it.
I also explained an experiment i have done, and the inventions i have designed and made.
I understand electrical z pinches, maybe you dont but here is one using a toroidal coil with DC electrical current. The charge/current of Rotating plasma doesnt obviously oscillatate like AC, it is travelling in 1 direction around the toroid, so the z pinch produced on the plasma in the center of the toroid is compressed just like the can is with DC electrical current. If im wrong about that PLEASE say so because i will know im speaking to the wrong ppl that dont even understand how electricity works.
Lets try this simple question...
If a fluid is compressed will it
a) flow to an area of lower density.
b) expand once it has flowed out of the mechanism that is compressing it?
c) create its own fields as current flows
d) all of above
Add on.. for the record that pepsi can was z pinched full of fluid and as a result it looks to have blown out the ends of the can. It takes a descent amount of force to do that.
