Inside the black hole the same structure is made, obviously the density of plasma inside the black hole is much stronger, notice the similarities between the larger magnetic structure to the plasma squatter man and the magnetic model of earth as shown previously
Please go on in detail about the internal structure of black holes
That's the best question so far, thank you.
Black holes arent all the same. The toroid inside a black hole of a 2 armed galaxy produce a dipole above and below the equatorial axis, inside either end of the larger dipole is a second smaller dipole, this is produced by the rolling around the toroidal axis. In a 2 arm galaxy the plasma completes 1 roll around the toroidal axis every 1 rotation around the poloidal axis. With a 4 arm galaxy, inside either larger dipole is a quadrupole just like the sun or earth, this weaker quadrupole is produced again by the rolling of the plasma around the toroid axis, this time 2 full rotations of roll are produced per 1 rotation of the polidal axis. Ie 720° of roll every 360° of rotation. This i believe is formed by a double helical wave rather than 1 720° wave. But it could be a mixture of both. This needs a lot more computing power to fully understand than what is currently available to me. Thats why we debate.
Obviously galaxies with multiple arms roll half as many times as how every many arms they have. The best example of this is Saturns sextupole, it rolls 3 times around the toroidal axis for every 1 360° rotation of the poloidal axis. Or 1020° every 360°
Black holes are made of superconducting plasma, hence the absence of electromagnetic waves from the surface, except at the polar jets when the plasma is non linear around the axis. Like any vortex this produces a repulsive force between the 2 plasma currents travelling in opposite directions either side of the axis.
The plasma travelling from the south suction pole, to the north expansion pole via the z pinch expands around the axis. The reason for the southern pole jet is because as the plasma expands in the very center of the vortex turns to vapour. The best natural example of this is an extermely fast water vortex, the low pressure at the center of the vortex axis evaporates the water and it expands outward in the opposite direction to the liguid going down the vortex.
The liquid plasma going down the vortex enters the z pinch, here is is compressed to unimaginable densitys by the toroid. It is then blasted into the north rotating vortex, where the plasma collides turning the superconducting plasma from laminar flow to turbulent flow. The plasma begins rotating with the north vortex and becomes laminar again or it gets shot out of the black hole in the north jet.
This area of turbulent chaotic plasma interactions is the most likely souce of the fusion by product.
The plasma then starts to make its way around the outside of the center toroid on it way back to the south pole to complete the circuit. This is where the turbine blades of the plasma reactor will be positioned, utilising the energy from the turbulent expansion of plasma. These systems exist in gas gaints like jupiter and as we know planets such as jupiter radiate to much energy, with out the ability to create fusion, or at the very least with out the abilty to create enough fusion to justify the level of energy released from the planets surface.
Dark matter can be considered superconducting plasma, and dark energy is that insane amounts of current that is generated from the speed of rotation. And no i have no idea of the math involved in that. I will leave them calculation for someone who actually like maths.
