All I wanted to do was to force on Vsync by default.
I got there in the end but so frustrated by the amount of time and effort I had to go for something this is suppose to be so easy, simple and basic to set settings that I had to struggle removing the new Command Centre despite uninstalling and trying to find a version of the previous Intel Graphics Control Panel to install and show up.
I simply click that an the Intel Control Panel appears in about a second.
I add Unrealtournament:
That's it and the tearing stops. Not hard is it and I thought that was a bit oversimplified an dumbed down.
From the beginningI installed the chipset drivers on this Lenovo T490's laptop but found later on with certain games and stuff tearing. So I find the Intel Control panel now here it seems:
Ridiculous. 8 SECONDS! to load that up.
License:Not pleased with having information collected but it gets better when they remove features like below.
I thought it looked like a social networking tool at first with that is at the bottom:
Why are these STUPID things in there that launch the web browser and URL.
Like that is so important that anything else.
What place does it have in such a tool that controls the graphics settings.
Don't you think that is just stupid?
As soon as I saw that I thought it is going to be crap and not give me what I want.
Options to control Anti Aliaising an Vsync not there.
Turns out I was right.
https://community.intel.com/t5/Graphics/Not-able-to-turn-off-vsync/m-p/366466/highlight/trueidata 01-14-2012 05:12 PM
There is no off option on my Intel Graphics HD display manager.
How do I force vsync off?
Allan_J_Intel1 01-19-2012 08:24 AM
Hi there!
The latest Intel graphics drivers does not provide an option to turn off Vertical Sync, you will need to take a look within your game options or programs settings for a place to disable such feature.
thanks
Allan.
Well that is very helpful isn't it.
https://community.intel.com/t5/Graphics/Trouble-finding-the-V-sync-option-in-Graphics-Command-Center/td-p/1438998MatthewTheFetus Beginner 12-15-2022 01:02 PM 5,243 Views
So I just downloaded the Intel Graphics Command Center on my laptop (hopefully the laptop isn't the issue here) and I wanted to force V-sync
Steven_Intel 12-22-2022 03:40 PM
Hello MatthewTheFetus,
The latest version of Intel® Graphics Command Center (IGCC) that was pushed to the Microsoft Store is indeed IGCC lite. This means that all game-related features have been removed and the display features remain.
Gaming related features have been moved from Intel® Graphics Command Center to our newest gamer focused user interface, Intel® Arc Control. We recommend that users who meet the minimum requirements for Arc Control install the application to tweak their gaming features, settings and for screen/game capture related features. Intel® Arc Control is bundled with our latest graphics software packages on Intel.com.
I had problems where I'd install the driver but the Intel Control panel service wouldn't appear or start in Services, according to the logs the files were missing in the driverstore but the folder was there so I manually copied them over and now the previous Intel Graphics Control Panel appears with the Vsync setting. I thought it was all put into c:\windows\system32 and the Driver sub folder.
I thought it was just Intel but I see Microsoft ordered it:
https://www.dell.com/support/kbdoc/en-uk/000134505/what-are-dch-drivers-and-why-do-you-need-to-know-about-themWhat are DCH Drivers?
Windows Declarative Decorative Componentized Hardware (DCH) supported apps and drivers are driver packages that install and run on Universal Windows Platform (UWP) based editions of Windows.
Note: Integrated user interfaces or applications are stripped from the driver package. When the driver is installed, it pulls the appropriate application from the Microsoft Store or where it is pre-installed on the computer.
Declarative (D): Installs the driver by using only declarative Information (INF) directives. Does not include co-installers or Register Dynamic Link Library (DLL) functions
Componentized (C): Edition-specific, OEM-specific, and optional customizations to the driver are separate from the base driver package. As a result, the base driver, which provides only core device functionality, can be targeted, flighted, and serviced independently from the customizations
Hardware Support App (H): Any user interface (UI) components that are associated with a universal driver must be packaged as a Hardware Support App (HSA). Alternatively, they must be preinstalled on the OEM device. An HSA is an optional device-specific app that is paired with a driver. The application can be a UWP or Desktop Bridge app. You must distribute and update an HSA through the Microsoft Store.
Note: UWP based editions of Windows, which started with Windows 10 version 1709 (Fall Creators Update).
Cause
How does this affect my Dell computer?
Moving to DCH drivers is a requirement from Microsoft for anyone developing drivers for Windows going forward.
Dell supplies copies of the drivers that are used for all its computers on its support pages. Windows drivers are changing to DCH as they are developed and updated. There is a chance that you can have driver issues if you are unaware of this change that started with Windows 10 (version 1709). Regularly update your version of Windows and keep your drivers up to date as recommended by Microsoft and Dell.
Resolution
Can I roll back to a legacy driver?
All the driver vendors recommend upgrading from Legacy to Windows DCH drivers. They all point you to your computer manufacturer for the latest driver updates. (Dell Support Site.) Most vendors actively try and discourage you from going in the other direction. (Going from a DCH driver back to a Legacy driver.) * Most driver vendors advise that it is a complex process that can result in system instability. Most have asked that you to contact them directly if you think you need to attempt it.
* UTTER BULLSHIT! All I do is find out the name of the whatever, download the driver, and install it and it appears in either the control panel, start menu or wherever and that's not hard. They seem to make it hard when it is not.
I find this hard: It SHOULD NOT need to or depend, Net framework to function for the "APP" and up to date, a Microsoft account, a stupid APP store to fin and install it and the package being available in this store.
https://www.intel.com/content/www/us/en/support/articles/000088086/graphics/intel-arc-dedicated-graphics-family.htmlDifferences Between Intel® Arc Control, Intel® Graphics Command Center, and the Intel® Graphics Control PanelThe Intel® Graphics Control Panel doesn't need to be installed manually.
Released with legacy graphics drivers.
The Intel Graphics Control Panel is included with the drivers mentioned below. If the Intel® Graphics Control Panel is not installed on the system automatically with the drivers mentioned below, your system must have newer drivers and we recommend installing the Intel Graphics Command Center instead.
On one occasion during my experiments trying to get the old panel to work I had to manually remove the Command Centre drivers and services which were still there after I selected to uninstall and delete the driver. Maybe they deliberately made it like according to the article above from DELL.
Released in the Microsoft Store in November 2018.
Visit the Microsoft Store.
I see Intel removed the VSYNC and other settings to another "APP" Arc, in the Appstore for gamers.
I want Vsync forced on all the time not just for games.
I find it stupid to split the driver package in half in the first place for all the basic things and just stick it on the APP store. I should be able to go in there and set things directly not depend on a whole load of things to have access to it.
In my case they appeared bundled with the installer from the Lenovo drivers but lacking the most basic features.
https://www.dell.com/support/kbdoc/en-uk/000134505/what-are-dch-drivers-and-why-do-you-need-to-know-about-themNote: Integrated user interfaces or applications are stripped from the driver package. When the driver is installed, it pulls the appropriate application from the Microsoft Store or where it is pre-installed on the computer.
I find it so much worse that Microsoft seems to be demanding that to access the settings of the driver, for it to only be accessible from from Net Framework "APPS" obtained from their Appstore.
What do you think?
