Author Topic: More audiophool ethernet switch BS  (Read 7991 times)
Offline madires
  • A qualified hobbyist ;)
Re: More audiophool ethernet switch BS
« Reply #25 on: January 20, 2021, 06:09:30 pm »
It's not just about jitter, packet reordering can occur also (very rarely seen in LANs).
Unless the switch has a really bad frame loss issue, I don't think it contributes to packet reordering.
It's not even the business of an L2 device. The only reason why this can happen is if it takes too long to switch the frame or it just got it lost, so the host has to send another one out of order.
For clarification:
IP: packet reordering
Ethernet: frame reordering
Packet reordering can happen when there are two links used for load balancing. Same for frame reordering, e.g. caused by link aggregation (incompatibilities, different algorithms, etc.).
Offline KubaSO
« Reply #26 on: January 26, 2021, 04:07:17 pm »
Linear supplies too slow? When a couple years ago you could buy single chip regulators that have >60dB of PSRR at least out to 1MHz, and similar load change rejection (yes I know I’m preaching to the choir, sorry couldn’t help myself). And that’s just buying an off the shelf chip. If one wanted to engineer something better, it’s no problem either, and due to the demands of deeply modulated loads as CPUs go in and out of “nap” modes at 10kHz rates, even stiffer regulators come out all the time. If anything, a switching regulator has inherent sampling and can’t really do much until the inductor current resets, so those have a hard Nyquist limit to their regulation bandwidth even if everything else was perfect. They make them multi-phase for a reason - it’s interleaved sampling just as the cheap digital scopes do to combine slow ADCs into a “fast” one (it also distributes the electrical and thermal lid across multiple devices, which is nice as well). If we were to be anal about it, a 5GHz linear PA in a WiFi router does “regulate” the output voltage at gigahertz rates 😅
Offline CJay
« Reply #27 on: January 27, 2021, 11:35:20 am »
It's just marketing bullshit because the manufacturer of the cheap crappy switch they're rebadging only supplies a switching PSU with it.
There'll be a 'sonic soundstage upgrade' some time in the future which 'flosses the ears of the listener with cotton buds made entirely from oxygen free angel wings' or some such bollocks.
The following users thanked this post: bd139, rgarito, JPNH20
Offline Terry Bites
« Reply #28 on: January 27, 2021, 05:42:56 pm »
Shameful brand name theft. It really made by Audio Research Sound Equipment
EE used to be a company that made fighter jets and fires and cookers and stuff?
(pant wetting)
Offline Sal Ammoniac
« Reply #29 on: January 28, 2021, 07:39:52 pm »
Here's another. A real bargain at only $395!
https://fidelizer-audio.com/etherstream-network-switch/
"That's not even wrong" -- Wolfgang Pauli
Offline CJay
The following users thanked this post: rgarito
Offline srb1954
  • Retired Electronics Design Engineer
« Reply #31 on: January 29, 2021, 12:31:05 am »
Do you get a copy of the fancy award certificate with your purchase?
I am sure that certificate would account for the extra $300 they charge on top of the Cisco price.
Offline Haenk
« Reply #32 on: January 29, 2021, 06:49:48 am »
"Positive Feedback Writer" sure sounds like some sketchy Amazon feedback scamming operation 8)
Offline AkiTaiyo
  • Country: ie
« Reply #33 on: January 29, 2021, 09:57:14 am »
Mods like this can't come cheap, and aren't something any electronics hobbyist could do  :-DD (more likely wouldn't do because they would know better)
-Input capacitor upgraded with high capacitance and low impedance tuned for optimal performance
-Safety resistors upgraded with high power from Vishay Dale on DC input stage, power regulation stage, and isolation transformer stage
-Re-energize power supply with special tantalum capacitors to reducing noise and interference in processor chip effectively
-Crystal clock is upgraded with high quality clock from Japan with noise reduction tweaks
-Components are soldered with high quality solder providing solid bass and dynamics
Input cap.. <$0.5
'Safety' resistors <$0.5
'Special' tantalum caps, probably <$2
Japanese clock xtal.. $2
'high quality' solder $1
Bullsh*t "Solid Bass and Dynamics" - $300..
When is someone going to release on of these with a GPSDO as the reference clock?
Offline CJay
« Reply #34 on: January 29, 2021, 01:08:55 pm »
When Rubidium standards were being ripped out of cell base stations and sold as surplus a few years ago there was a small but expensive market in CD player upgrades using Rb standards programmed to whatever the common clock frequency is in CD players, comletely ignoring the fact that the output of a Rb standard is usually not as good for aduio as the cheap crystal oscillator they've replaced.
There have been a couple of whispers of GPSDO boards being used in audio but as an idea it doesn't seem to have taken root yet
Offline srb1954
« Reply #35 on: January 30, 2021, 12:09:17 am »
The audiophools will next be claiming that you can only get the ultimate listening experience if all parts of your system are synchronised to a single high quality master clock.
So the obvious next step would to have a brain implant hooked up to the GPSDO to ensure that the listener is also synchonised to that master clock.
The following users thanked this post: JPNH20
« Reply #36 on: January 30, 2021, 09:24:51 am »
Cue the search for the ultimate audiophile clock; a pulsar that we can ship them all off to.
Offline JPNH20
« Reply #37 on: January 31, 2021, 08:31:36 am »
In the past six or eight months I started purchasing older valve audio amps and receivers and rebuilding them. Just as a hobby. I enjoy working with the older technology on occasion and some sound nice.
Anyway, this has led me to spend some time on various "audiophile" forums to get schematics yada yada. I've come to suspect that a lot of these people may not have much in their lives other than one upping each other or feeling a sense of superiority by dropping the name of an expensive piece of gear they purchased.
I would open a thread from someone new to the hobby asking for advice on purchasing a basic item like a phono preamp with a budget of $200. The number of I saw people responding with advice like the following:
"I own such and such preamp (lists one that costs $5k) you should just save your pennies nothing under $200 is good" was astonishing. It's like a certain number of "audiophiles" get off by alienating someone new to their world in a stupid display of attention whoring. Audiogon was by far the worst and I can't stomach visiting that forum. The snobbery and the one up manship is just off the charts.
Anyway that's my 2¢ no one asked for.
Offline JPNH20
« Reply #38 on: January 31, 2021, 08:53:16 am »
Theres a whole forum of fools sucked in by the marketing BS.. Its worth a read just for the complete lack of understanding about how ethernet works and the mis-use of terminology..
https://community.naimaudio.com/t/english-electric-8switch/8345/
Someones making a lot of money from this!
Quote from the forum:
Very happy with my EE switch. It’s provided a blacker background so I can hear deeper into the music plus the tone and timing are just right. Ended up switching to Catsnake 6a floating ethernet cables and sold my Vodka and Cinnamon ethernet cables as they sounded lean compared to the Catsnakes. I also added a Paul Hynes SR4T LPS and it made a substantial improvement over the stock switching power supply. Very happy with this set up!
Was just reading through the thread and some of those people have got to be schills from the switch company. There's no way anyone is that brainwashed(I hope). Even after being presented with evidence of it being a $30 cheap Chinese switch there's a group of about five users trying to legitimize the markup and get others that are skeptical onboard. Those have to be plants.
Offline CJay
« Reply #39 on: January 31, 2021, 09:25:06 am »
The one upmanship on the audio forums isn't exclusive to those places, it happens everywhere, a friend of mine contests that anything with two wheels, a chain and pedals that cost under £1000 isn't a bicycle (he is, to be fair to him, half joking) but there are cycling forums where you will be laughed out of the forum if you don't have unicornium based carbon nano tech frame combined with wheels made from quantum foamed dark matter and that cost more than a small 3rd world country's entire education budget.
Same applies to ham radio, to test gear acquisition syndrome, fishing rods, cars, all sorts.
It makes me wonder just how empty their lives are that they have to invent such ludicrous hyperbole to justify their purchase of the latest, greatest BS tech or lose face.
I wonder just how many of the positive reviews are only positive because they don't want to be the one to reveal the emperor isn't wearing the most beautiful new suit and thus lose the favour of the community and manufacturers?
As for posting the info about it being a cheap mass market switch, yeah, they'll never admit they've been conned unless everyone else admits it at the same time because they're terrified of being deemed 'unworthy' of their place in the forums.
All it would take is one alpha member to tell them it's BS and then they'd fall like dominoes.
The following users thanked this post: rgarito, AVGresponding, JPNH20
Offline dietert1
  • Country: br
    • CADT Homepage
« Reply #40 on: January 31, 2021, 04:00:16 pm »
Try to find out where the money comes and where it goes. Start considering everything an ad, i mean whenever a brand name is mentioned. Somebody is paying for running forums, guess they can afford contracting influencers.
Regards, Dieter
The following users thanked this post: CJay, JPNH20
Offline Terry Bites
« Reply #41 on: February 08, 2021, 05:40:07 pm »
I wonder where this my mic is bigger than your mic crap started on YouTube. https://www.maxim.com/news/hitler-one-testicle-2015-12
Offline rgarito
  • STM32, ARM, x86, FPGA, Firmware, Linux/FreeBSD
« Reply #42 on: February 09, 2021, 04:11:06 am »
But of course, the consumers don't know this. All they know was how bad jitter can f*ck your system up in the old days, and they will look for keeping jitter out of every chain of their system, so why not make some money on this?
I think you give them way too much credit!
Offline CJay
« Reply #43 on: February 09, 2021, 07:40:01 am »
I think I agree, I think they know how much they were told jitter fucked up theirsystem, but would have a hard time recognising or demonstrating it.
Offline GridWork
« Reply #44 on: February 10, 2021, 02:54:34 pm »
Also from the same company to go along with the Audio grade ethernet switch:
Audio grade ethernet cable:
https://soundorg.com/sarum-t-streaming-cable/
Only $5000 for a 3 meter cable.
Offline Daixiwen
  • Country: no
« Reply #45 on: February 11, 2021, 09:02:22 am »
I'm very disappointed in the lack of technical details on the internals of that cable. Of course it's directional because Ethernet packets only go one way.
